#4863
Thats pretty cool. Im actually going to grab a Samsung Galaxy Mega and put it inside the nav screen. That way it can fold down and disappear. I want to keep this looking stock. I went all out on my last rig. Now I just want subtle things. Nothing flashy or anything to grab a potential thiefs attention.
#4864
#4865
![Cool](https://g35driver.com/forums/images/icons/icon6.gif)
At 122,000 miles, replaced both front lower control arms; tie rod end links, front lower ball joints, sway bar bushings as well as links. Ordered all OE equipment and did all the install myself. Once I started rolling, it was over before I knew it. Finished the project off with new rear cooper tires and an all wheel alignment.
Had an issue with the brake light, vdc light, and slip lights coming on. Topped off the brake fluid level and problem solved. Sometimes it's just the simplest things. (I post this for those who are having similar issues)
The G is now cornering like a champ. Next is rear shocks and shock mounts. If I have time I'll likely replace the upper rear control arms as well.
Next year I'm planning on installing a dual exhaust "cat back" then perhaps a bit later investing in headers and high flow cats
#4866
Well today I was in a friends car and I noticed that his Stock Bose sounded much nicer than mine. The bass was hitting a lot stronger than mine. I asked him and he told me that he swapped the stock Bose sub for a G37 Sub... He said it fits perfect and hooks right up. I was blown away! I went on eBay and found one from a 2010 G37 Sedan and ordered it for $44. If this works, I am posting a DIY...
I also picked my car up from the stealership as they installed a new Front knuckle for my blown Ball Joint... Extended Warranty FTMFGDW!!!!!!!!!!!!!!!!!!!
Had blown knuckle ball joints as well. Advance auto parts has the tool loaner program I used their ball joint press kit and replaced those ball joints myself. Saved tons and picked my own parts. Bet she handles better now?
#4872
![Name: B656CB93-4B96-4BAA-804D-3D3D4EB136F8_zpswnrmliiw.jpg
Size: 101.6 KB](https://g35driver.com/forums/attachments/g-spot/182380d1501232904-what-did-you-do-g-today-b656cb93-4b96-4baa-804d-3d3d4eb136f8_zpswnrmliiw.jpg)
#4874
