#6931
Took apart the interior of the G... Another few days and its sawzall time... The wiring is crazy for these cars.
Is this how you change a spark plug?
Finally got the rear timing cover off. After beating prying and almost giving up on life. I discovered I missed 4 bolts. 2 under the oil pan and 2 in plain sight... I feel really really dumb.
Took off timing cover, it was more of a pita then I imagined it would be.
One of the screws on the passenger side chain guide was almost completely unscrewed, found that interesting.
This might be my first post figured I would make it good... What I did for the last month or two.
#6932
Discovered the source of the chirping from my engine bay. Ended up replaced the A/C tensioner pulley (bearing was gone) as well as both belts. Literally only took me 30 minutes once I got the car in the air. Very good use of $93.
It was 20% tint all around but I failed inspection, it annoys the crap out of me. And idk why everyone hates the stickers, I absolutely love them lol. As for daily'ing this height, it can be annoying. Yes it scrapes, but not near as bad as you would think. It's a little stiff but to be honest I really need stiffer springs, the 10k front and 8k rear are a little soft for how low the car is. But I absolutely love it, and the crazy rear camber is soon to be no more, I have new tires which will bring the -8. 5 to a more reasonable number.
I'm jealous of you guys. I was on a mission to have a bad *** G sedan and got recently layer off after the Xmas season without an emergency plan plus I'm single so didn't have that Financial back up some of you guys have. Hopefully god willing I can get back on my feet and go back to playing with the car. For right now I'm gonna be a reader and drink this vodka and sprite that's in my cup.
#6933
#6934
Car has 208k miles on it, and someone drifted it into a tree before I picked it up.
I have a 04 Z and lots of interchangeable parts im going to keep, the rest will get cut up and sent to scrap...
#6935
Had the wheels balanced about a week ago so got a good chance to have a look underneath without laying on the ground. Also noticed cupping on the inner edges of the fronts which I suspect is mainly down to excessive toe out so I sorted that out today, will see how the wear changes - could also be due to bad ball joints or bushes but haven't felt/seen any obvious play. Shocks seem fine too...
#6936
See responses above in red. My issue with the stickers is that to me they scream "Look at me" which implies of a level of immaturity of the owner, like you're asking people to look at the car. I think the car should command attention by being carefully/tastefully modded and different enough it turns heads when people see it. But just my .02, we're all different.
#6937
As a side note, how many stingers are on your car? I only see one, so I don't understand the hate on stickers...
#6938
Thanks! I'm not a fan of the rear camber, front looks great to me but I'm not pleased with the rear. And as for the stickers, I have 8 and a 9th on the way. If you count the wrap as a big a** sticker then it's 10 total lol
#6940
#6942
Ah I see. And i agree the front looks about on point but the rear a bit much, but at least the stickers aren't all close to each other, and the wrap doesn't count, looks dope man! Going thru your build thread when I have the time
Conissah (01-24-2017)
#6944
