G35 & G37, Coupes & Sedans
Suggestion on headlights?
Old Apr 20, 2012 | 11:02 PM
Keggr626's Avatar
Just to be certain. It is a haze and not moisture right?... And I agree I wouldn't try puffing the inside
Old Apr 21, 2012 | 12:06 AM
prinny's Avatar
%100 sure that it's haze
Old Apr 21, 2012 | 01:30 AM
TORETTO's Avatar
retrofit one of these
Old Apr 21, 2012 | 01:31 AM
TORETTO's Avatar
Old Apr 21, 2012 | 01:38 AM
AJY's Avatar
AJY
Seems legit
Old Apr 21, 2012 | 01:42 AM
NFSP G35's Avatar
? = 2B || !2B
The inside of the headlights has a coating on it so I wouldn't recommend buffing it. I don't think you'd be happy with the results. You'd be better off buying a new/used one.
^Best post in this thread.
Originally Posted by prinny
Damn hmm..
What about something like this?
http://www.ebay.com/itm/03-04-Infini...item4ab594d676
That is an option.
Might also consider doing a projector retrofit based off those.
Bi-Xenon projectors are really the key to the absolute best light output, trust me I know
Also, unlike reflectors, with projectors you can pack 55w HIDs and make the sun envious
Originally Posted by gary c
Prinny, post a WTB '06 projector headlights thread on Private Classified under exterior for your sedan. Used set should be $300 in mint condition maybe less....Gary
Um, that not so much worky on a sedan
If you're going to spend the $$ get the projectors, those are the headlights our first gen G35s should have come with. I doubted other members suggestions on this subject for a couple years, I was very wrong!!
Gary
Unfortunately, the Sedan didn't come with projectors until 07 when they changed the body style. But even if they had, it wouldn't do the OP much good as 05-06 sedan headlights are not interchangeable with the 03-04 ones.
Old Apr 21, 2012 | 02:08 AM
NjMatteSedan's Avatar
Damn hmm..
You would have to get an aftermarket H1 HID kit. It doesn't work with oem hids
Old Apr 21, 2012 | 02:16 AM
NFSP G35's Avatar
? = 2B || !2B
^Those have the HID kit with them.
Old Apr 21, 2012 | 02:23 AM
That is an option.
Don't mean to threadjack but do you know if i can put 55w hid bulbs on a ballast that's not 55w?. Im not sure how many watts my hid kit is but im gonna install projectors soon and i think i need new bulbs because the driver side bulb sometimes i have to turn the headlights on and off several times in order for it to cut on.
Old Apr 21, 2012 | 02:51 AM
Ohh i dont know how i missed that. I just gave a quick glance at the headlights and closed it
Old Apr 21, 2012 | 03:01 AM
NFSP G35's Avatar
? = 2B || !2B
Bulbs are more than likely the same. It's normally the ballast that determines wattage.
Old Apr 21, 2012 | 03:05 AM
So it doesn't matter what wattage bulbs i get? They might not be the same brand as the ballast
Old Apr 21, 2012 | 03:52 AM
prinny's Avatar
Wahhh. Always though they were interchangeable.. hmmm
prinny's Avatar
Originally Posted by ME GUSTA
Best mod EVER!
Old Apr 21, 2012 | 03:54 AM
  #30
^ triple projector
