G35 & G37, Coupes & Sedans
Rubbing when going around corners
Old Apr 24, 2012 | 12:55 AM
gary c's Avatar
That sounds like the fender liner rubbing against the tire! What does your G feel like going down the road, like you're on the ocean? Take your G to an independent brake/alignment shop in your area and ask them if you need shocks and explain the noise you're hearing. With 100K miles on OE shocks (maybe) that could easily be the cluprit....Gary
Old Apr 24, 2012 | 01:24 AM
xXThirty-FiveXx's Avatar
Hi Gary, thanks for the advice. I had the G in for a alignment two weeks ago. They said everything was fine. Other then a link on the rear sway that they tightened, they said it went well. The g holds perfectly straight if I am not holding the wheel. They never said anything about the shocks, maybe they never looked. How can I tell myself? I can put it up on blocks tomorrow. I can also go back there and ask what they think. Thanks
Old Apr 24, 2012 | 02:10 AM
herrschaft's Avatar
^If the shocks are bad, the car would feel very loose and it would sway a lot. Handling would obviously be worse.
Marlin84
Apr 1, 2020 12:52 PM
DRG35R
Jan 31, 2016 07:14 AM
prinny
Nov 22, 2015 11:07 PM
alinero718
Sep 27, 2015 09:35 PM
