G35 & G37, Coupes & Sedans
G35 coupe Restoring Suspension
Old May 9, 2012 | 07:37 PM
stevensG35's Avatar
Smile G35 coupe Restoring Suspension
I just bought a 05 G35 coupe that was lowered with eibach lowering springs 1.1 inch drop in the front, 1 inch in the rear. It has 19 inch afttermarket rims ,what would be the best way to raise car back up. Should I find stock springs or use coilovers??... Currently the back tire on the inside approx 5 inches is wearing very fast. (too much negative camber) or should i keep it lowered and get the a rear camber kit. Front tires seem to be wearing ok
I rather not have the car so low to the ground as im afriad of scraping or ripping the Exhaust off.
Old May 9, 2012 | 07:42 PM
.cakestar's Avatar
if you arent into modding, just pick up oem suspension.
Old May 9, 2012 | 07:45 PM
stevensG35's Avatar
If i do bring it back up with a oem suspension do I need the camber kit?
Old May 9, 2012 | 08:25 PM
.cakestar's Avatar
no, with the oem suspension you will be in spec. Might want to get an alignment anyway but you wont need to get adjustable cambers.
Old May 9, 2012 | 08:28 PM
Dubi2087's Avatar
I would leave it Lowered and get a camber kit and an alignment. That would probably be the easiest way. But thats just me.
Old May 9, 2012 | 08:32 PM
Footballmania32's Avatar
If the inside ~5 inches of your tire is wearing your toe is off. Camber usually only affects the inside 1-2 inches of the tire.
As far as raising it back up, just pick up some OEM suspension.
Old May 10, 2012 | 02:30 PM
VMRWheels's Avatar
If you're not into modding, definitely just pick up OEM suspension. In regard to the tire wear, you may just have a bad alignment.
Old May 14, 2012 | 01:38 PM
Parker6's Avatar
StevensG35,
If you want, I have a set of OEM springs from my 06 coupe...I have an add in the classifieds if you want to check it out.
Old May 14, 2012 | 04:15 PM
tylerxfire's Avatar
if the cars only lowered with the eibach pro kit then a good alignment should get u straight..if its the sportlines then u will need a rear camber kit...
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
Carlos_G358696
Jul 18, 2015 03:22 PM
