G35 & G37, Coupes & Sedans
tranny fluid refill
Old May 29, 2012 | 01:44 PM
jonathanmayea's Avatar
tranny fluid refill
Performing transgo vb upgrade this weekend.. goin to dealership today to pick up new tranny fluid.. can someone explain to me how to refill the vb with fluid after installation? I have an 06 coupe.
Old May 29, 2012 | 02:12 PM
Silencer_0's Avatar
You fill it up from behind the plenum, to the left of it. , I believe it's a 10mm bolt.
And just in case you haven't seen it: https://g35driver.com/forums/engine-...y-upgrade.html
Old May 29, 2012 | 03:21 PM
Is that under the hood or by the vb???
Old May 29, 2012 | 05:02 PM
Silencer_0's Avatar
Under the hood, the dipstick behind the plenum.
Old May 29, 2012 | 08:25 PM
Ok finally found that small thing. i have kinetix intake manifold so it was well hidden.. i actually had to bend the pipe to get the cap off.. i bought s matic fluid. the cap says j matic caution.. so im assuming i did right? thanks man!
Old May 29, 2012 | 08:36 PM
thescreensavers's Avatar
Mr.202?
Matic-S Replaced Matic-J, Matic S is fine. You can buy the fluid much cheaper online but since you are doing the upgrade soon, Id call around should be anywhere from 11-13 bucks a quart, some dealers want 20 which is a rip.
the VB upgrade is pretty intensive, if you don't know how to fill the transmission up with fluid..., all I am saying is make sure you know what your doing lol.
Old May 29, 2012 | 08:37 PM
JaE35's Avatar
Moderator
G35 Sedan
Old May 29, 2012 | 08:50 PM
Just bought 5 quarts today. 9.18 ea
Old May 29, 2012 | 09:18 PM
Silencer_0's Avatar
Don't you need 8 quarts?
Old May 30, 2012 | 12:17 AM
8 if u flush.. 5 for vb upgrade
Old May 30, 2012 | 12:28 AM
**** ur right 8 quarts. Damn I only bought 5 n drove 40 miles to get me.. U think I can use the 5 and 3 off of wat I drain out?
Old May 30, 2012 | 04:17 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
Ummmm... I have to agree with screensavers here... You can't find the trans fluid dip stick and don't know how much fluid to buy for doing a Transgo... You should probably leave it to a professional.
I've done 4 TransGo installs so far and am doing 2 more in the next few weeks so trust me when I say that this mod isn't for the average Do It Yourselfer. Ill admit that even I was a little nervous on my first install and I have years of experience working on cars for a living.
Remember that a new valve body costs $1,000 if you mess anything up...
Old May 30, 2012 | 04:26 AM
Blue Dream's Avatar
I drove ttrank's car solo
Folks the transmission holds 10 3/4 qts. of fluid.
Old May 30, 2012 | 09:01 AM
Thanks for the advice.. ive been a collision repair tech for 13 years strong now.. sure im a little nervous but i know o can handle this.
I just needed to know exactly how much fluid i need to put back?
Old May 30, 2012 | 10:05 PM
Collision and body work have nothing to do with transmission internals... Just saying.
You'll need approx 8 quarts give or take 1/2quart
