G35 & G37, Coupes & Sedans
Flip key
Old Jan 6, 2013 | 09:14 PM
916sgm's Avatar
Flip key
I have researched and haven't found what I'm looking for... I am interested in a flip key from eBay, and its states it comes with a chip, so all that is required is getting the key cut... And it's pretty cheap, around $20... Is that all that is required, or is the transponder chip it come with complete crap?...Has anyone had any experience with this kind of key?..
Old Jan 6, 2013 | 09:22 PM
KrazySouthG35's Avatar
You have to have the chip programmed as well
Old Jan 6, 2013 | 09:29 PM
916sgm's Avatar
Ya I forgot to add that part as well... But what my real question is, are the chips that they come with any good?... I read a few posts that are from 2009 saying the chips don't work and they had to use their oem ones...
Old Jan 7, 2013 | 12:49 PM
falcor's Avatar
the transponders that come with the ebay keys don't usually work
Old Jan 7, 2013 | 01:29 PM
Ye_Budyy's Avatar
It might or might not work...just depends on luck...I rocked the flip key for almost 8-9 months and loved it but after a while it just started becoming dull and I felt like it was going to break.
Old Jan 7, 2013 | 11:18 PM
BowWizzel's Avatar
For the flip key all you need to do is transfer internals from your FOB, get key cut, pull out that little chip in your OEM key & put in into the flip key which has a slot for it inside.
Old Jan 8, 2013 | 01:33 AM
SAMzG35's Avatar
G35
I've been rocking one for over a year. It's not bad. Feels cheap for sure.
I had one key only and bought this as back up. Remote with chip and uncut key was 20 shipped. Can't beat that.
Had it cut locally and programmed and works fine.
Also what the guy above me said. You can remove the chip from your current key and set it inside the flip key (it's just glued there with epoxy type glue) and call it a day. Just get the key cut at this point.
Old Jan 8, 2013 | 01:51 AM
916sgm's Avatar
I really want to find one that already has a WORKING transponder in it, where I only have to have the key cut and the transponder programmed... I only have one key..
Old Jan 8, 2013 | 02:34 AM
SAMzG35's Avatar
G35
Yep. This is exactly what I have
http://www.ebay.com/itm/INFINITI-FLI...ddd2e4&vxp=mtr
All you gotta do is cut and program
Old Jan 8, 2013 | 12:51 PM
916sgm's Avatar
That's what I've been looking for! Thanks SAM! How much does it usually cost to get the transponder programmed?..
Old Jan 8, 2013 | 03:44 PM
SAMzG35's Avatar
G35
No problem, depending on your city I guess. Where I live everything costs more. It was 80 bucks including cutting IIRC
Old Jan 8, 2013 | 04:22 PM
Adro's Avatar
I had 3 keys programmed for $60 total. Get a few and do them together, usually you'll get a better deal
Dallsinghjr1
Sep 17, 2023 11:25 AM
cpmiller22
Oct 10, 2018 10:54 AM
G35xdriver04
Nov 7, 2015 08:31 PM
