G35 & G37, Coupes & Sedans
Ok to use 87 octane gas on an 04 g35 sedan AT?
Old Oct 4, 2013 | 12:32 PM
  #31
telcoman's Avatar
Veteran: Army
Originally Posted by thegreatkwijibo
Old guys
I used to be young
My 55 Chevy 3 speed stick on the column
It had a heater and a five button AM Radio
Telcoman
Old Oct 4, 2013 | 12:37 PM
  #32
Mustang5L5's Avatar
I'll still do consulting work. I'd just like to get away from the 9-5 40hour work week stuff.
What i do is kinda fun anyway
Old Oct 4, 2013 | 12:54 PM
  #33
thegreatkwijibo's Avatar
Originally Posted by Mustang5L5
I'd like to retire by 50.
I don't think I could ever retire I get bored too easily.
Originally Posted by telcoman
I used to be young
Telcoman
55 Chevy
Old Oct 4, 2013 | 01:58 PM
  #34
djzachtyler's Avatar
Does anyone have an 03-04 manual?
Can you post what it says for recommended fuel octane?
lemme run out to the car I'll post up the stuff from my 04 6MT manual.
Old Oct 4, 2013 | 02:13 PM
  #35
here we go.
Old Oct 6, 2013 | 06:54 PM
  #36
kevink's Avatar
Originally Posted by taimysho0
hello, i bought an 04 g35 sedan as a beater, i dont really care too much about longrun impacts as im not planning to keep the car for more than 2 years (using for baby seat access, i came from a coupe).
ive read some mixed threads on which gas is ok, my gas tank doesnt have a sticker thay says "recommended". however is it really ok to use 87 though? or is premium required
OK to use 87 if you aren't driving hard. I normally buy what I'm in the mood for when I buy gas. Sometimes I think it isn't TOO much more for 91 octane. Other times, I look at the $0.34/gallon difference, and buy lower grade.
The coupe required 91.
Now, if I drive into the mountains, where low grade is 85 due to the elevation, I still buy at least 87.
Old Oct 6, 2013 | 06:56 PM
  #37
kevink's Avatar
The scanned image above essentially matches what the owners manual says in the 04 manual. Recommended 91 in the sedan. Required in the Manual Sedan and the Coupe.
Old Oct 8, 2013 | 02:40 PM
  #38
Play123boi's Avatar
I wouldnt its only a few dollars difference....
Old Oct 8, 2013 | 08:18 PM
  #39
stockae92's Avatar
I did tried 87 for a little bit, but I notice that I got slightly better mpg when using 91.
Its not worth the gas price difference for me.
Old Oct 9, 2013 | 10:07 AM
  #40
wasjr's Avatar
Not to hijack the thread, but for those that use 91 is this the premium or mid-grade? Around here we don't have 91 octane. We have 87, 89, & 93. Does the 91 replace the 89 or 93?
And the 03 manual is the same as posted above.
Old Oct 9, 2013 | 10:34 AM
  #41
Gman56's Avatar
91 is the same as 93.you must be above sea level !93 is for sea level.
Old Oct 9, 2013 | 12:30 PM
  #42
Mustang5L5's Avatar
91 is considered premium fuel. But learn to use the octane numbers and not misleading labels such as "premium" or "regular". Owners manual states 91+, so running 93 will satisfy this.
93 octane tends to be found at lower altitudes. The lower you are in altitude, the higher octane you require to prevent detonation. At higher altitudes, you won't fine 93 octane at all and might see 85, 87, 89 and 91 at the pump.
Old Oct 12, 2013 | 11:57 PM
  #43
Lartytiejdke3's Avatar
91 is considered premium fuel. But learn to use the octane numbers and not misleading labels such as "premium" or "regular". Owners manual states 91+, so running 93 will satisfy this. 93 octane tends to be found at lower altitudes. The lower you are in altitude, the higher octane you require to prevent detonation. At higher altitudes, you won't fine 93 octane at all and might see 85, 87, 89 and 91 at the pump.
Always wondered why here in OK they pretty much only have 91 and back home in Jersey it's 93
Makes sense
Old Oct 14, 2013 | 08:31 AM
  #44
Turtles_ride's Avatar
Sunoco here in Canada, and Niagara Falls NY, has an Ultra brand with 94 Octane, I strictly use it in my crotch rocket, but in my 03 G35 I just use the 87 octane which the advertise as having upto 10% ethanol in it as well. I'll also go to the Indian reserve in Louiston NY and get their 87 Octane regularly just because it's about 35 cents cheaper per gallon then anywhere else, which saves me hundreds of dollars in a year between the 2 vehicles I fill up there regularly. I don't really notice too much of a differene in performance, but I don't drive my G very hard anyways, its my daily driver.
Old Oct 14, 2013 | 10:02 AM
  #45
Mustang5L5's Avatar
I wish I could find fuel that was 0% ethanol. All we have here is 10% ethanol. Running pure gas would give a small bump in fuel economy.
