G35 & G37, Coupes & Sedans
Axle/drivetrain upgrade help
Old Apr 26, 2015 | 05:27 PM
Jkuti13's Avatar
I own a very low mileage 2006 g35 coupe and as the topic states I'm doing a swap for my engine and trans to multiply my power. As of now I have the engine the trans and full swap kits/adapters for both. I'm getting stuck when it comes down to my axles and rear end/differential. Which rear end would be my best bet to support the most power? And also any advice is appreciated
Old Apr 27, 2015 | 01:46 AM
herrschaft's Avatar
How much power are you expecting? The differential is fairly solid. I forget the brand but there are aftermarket axles available, there's multiple threads in the drag section on My350Z where they're mentioned.
Edit: DSS axles
Old Apr 27, 2015 | 12:37 PM
Spartan268's Avatar
What engine are you swapping in for?
Old Apr 27, 2015 | 05:10 PM
WhosUrBuddiee's Avatar
Dont swap it until it breaks.
Focus on actually getting the swap done first. Odds are, it wont happen.
Old Apr 27, 2015 | 10:45 PM
Jkuti13's Avatar
No I'm swapping w a 2jzgte (supra) non vvti, with a t56 magnum transmission. All I need is axles and a differential that can handle over 700hp
Jkuti13's Avatar
Odds are it's already happening :,)
Old Apr 27, 2015 | 10:48 PM
Jkuti13's Avatar
Not trying to sounds like an a** but I've had too many people underestimate me, with 20,000$ a lot can happen , in my case it's an engine swap. I need help w the drivetrain
Old Apr 30, 2015 | 02:57 PM
Mustang5L5's Avatar
If you are running street tires, you might be perfectly fine on the stock diff and axles. It's a 7.88" ring gear, so shearing the teeth off the ring gear might be possible if you launch on slicks. You can make it a little resistant by gearing down to a 3.3 FD (or lower if available)
If you are just building a high power street car, odds are you'll just blow off the tires before reaching the limits of breakage. if you are setting up for drag racing, then you are looking at about $1K just for axles
https://conceptzperformance.com/Cart...ype=350Z&CA=34
It really depends on your end use of this car.
Old Apr 30, 2015 | 03:59 PM
Jkuti13's Avatar
I was planning on the quaiffe LSD it's a good one. The only problem I'm seeing is the new engine and trans not lining up with anything
Old Apr 30, 2015 | 04:57 PM
It really has nothing to do with you. Being on this forum for over 10 years now, I have seen hundreds of people post threads about questions for this future FI or swap plans... only for it to never happen. I can say probably only 1 in 20 threads every actually happen.
Old Apr 30, 2015 | 06:01 PM
Jkuti13's Avatar
I've been saving my money for a few months. I know it's going to be expensive. I completely see where your coming from but I've been saving up just to get all this. I know for a fact I'm getting the 2jz, I'm stuck between saving a little money between the getrag and t56, I need to get a custom cooling kit for the tiwn turbo setup which may be some extra bucks and basically the biggest concern at the moment is how in going to run the engin/trans to the rear wheels the best. I'm not bullshitting. I just need some help
Old Apr 30, 2015 | 06:26 PM
If it happens, I would be pleasantly surprised. I am assuming you are buying a full motor with tranny. So why not just use the getrag? They can easily handle your power goals. Seems to be more expensive and harder to use a T56 converter, custom flywheel, ect. Or why not just use your G35 CD009 trans?
http://collinsadapters.com/index.php...a36-steel.html
Old Apr 30, 2015 | 07:12 PM
Jkuti13's Avatar
I probably going to go with the getrag, all together complete engine with tiwn turbo and getrag is 10,050, and my savings goal is at 20,000, I have enough already for the engine and getrag just want everything altogether
KruZZe
Feb 27, 2023 05:04 PM
g.spot
May 9, 2016 10:54 PM
NyCrAzY
Oct 1, 2015 09:19 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
