G35 & G37, Coupes & Sedans
stranded in florida need help burning coils to.
Old Nov 14, 2015 | 05:14 PM
deathdoakill's Avatar
ok so here we go I have an 04 g35 for the past couple days I have had a no start issue where the car just died today finally started and threw out a code for cylinder 5 I pulled the coil saw it was melting so I promptly replaced it after new one was installed I started her back up and within the 5 seconds it took to walk from the ignition to the front of the car the new coil pack was starting to melt and was smoking need help its possible I'm thinking I could have a bad ecu anyone here ever experience this????????
old coil
new coil
Old Nov 14, 2015 | 07:05 PM
Frankieg35's Avatar
You using oem coils or shirt aftermarket ones??
Old Nov 14, 2015 | 11:36 PM
andrewvk's Avatar
ecu doesnt send voltage. just signal. even at constant rate your coil shouldnt melt. not saying it cant, just saying it shouldnt. most likely cause is a short in the harness.
Old Nov 15, 2015 | 09:29 AM
telcoman's Avatar
Veteran: Army
Follow the troubleshooting steps in the FSM
http://www.nicoclub.com/FSM/G35/Sedan/2004/ec.pdf
"The engine has an ECM to control major systems such as fuel con-
trol, ignition control, idle air control system, etc. The ECM accepts
input signals from sensors and instantly drives actuators. It is essen-
tial that both input and output signals are proper and stable. At the
same time, it is important that there are no malfunctions such as vac-
uum leaks, fouled spark plugs, or other malfunctions with the engine...."
See diagram on page EC 92
I'm wondering if a shorted #5 spark plug could be the cause of your problem?
It might be more economical to let an Infiniti dealer find the root cause of your problem?
With a sixteen year old vehicle perhaps its time for a new one?
A new one comes with all new parts and a warranty
Good luck
Telcoman
Old Nov 15, 2015 | 01:36 PM
Old Nov 15, 2015 | 01:44 PM
No it wasnt an aftermarket coil it was oem and no im not getting a new car ive put allot if work into this car new engine new transmission its ran for 2 years an this is the first time ive ever had an issue. Telco thanks ill look into this info an see what i can come up with.
Old Nov 15, 2015 | 08:17 PM
Blue Dream's Avatar
I drove ttrank's car solo
I'd try replacing the spark plug and see if that fixes the issue. Cheap possible fix even if it doesn't work.
Old Sep 26, 2016 | 09:30 PM
InsanePacman's Avatar
Hey was this issue solved?
I had the same thing happen but not the car doesn't start at all and #2 coilpack gets super hot while trying to start it.
Old Sep 27, 2016 | 09:20 AM
telcoman's Avatar
Veteran: Army
Originally Posted by InsanePacman
........ #2 coilpack gets super hot while trying to start it.
It gets hot due to probably shorted windings?
Measure the resistance from a good one to compare
Telcoman
Old Oct 1, 2016 | 05:24 PM
Telcoman
I will test resistance soon, but noob question first... what is a winding? lol
Old Oct 1, 2016 | 06:08 PM
telcoman's Avatar
Veteran: Army
A winding is part of a coil inductor. Switching 12v on and off rapidly induces a high voltage in the secondary winding to generate the high voltage necessary to fire a spark plug.
This part is known as a coil pack. One required for each cylinder
http://www.nicoclub.com/service-manu.../Sedan/2004/ec
See page EC 590
You may want to consider having a pro diagnose your problem.
http://www.carsdirect.com/car-repair...ulty-coil-pack
Telcoman
Old Jun 4, 2023 | 06:02 PM
Dolo's Avatar
G35 Sedan
Check all your ignition and sensor fuses
Possibly a short or blown fuse
Thebaws11
Jul 2, 2021 11:36 AM
magnetism80
Feb 1, 2019 10:00 AM
Dat Kid
Nov 23, 2015 11:18 AM
BigNiniPanini13
Sep 15, 2015 05:55 AM
crakke
Sep 1, 2015 04:23 PM
