G35 & G37, Coupes & Sedans
Can't find door Escutcheon in my color, what can I do?
Old Aug 23, 2017 | 12:11 AM
sah302's Avatar
I've got a G35 in Blue Pearl Metallic, color code B16. Have not been able to find any website that holds these parts. I need a keyhole escutcheon cuz someone ripped mine off trying to rob it. Also need a rear bumper too in that color and it doesn't seem to exist. I guess the color got discontinued?
Old Aug 23, 2017 | 02:07 AM
Urbanengineer's Avatar
Your local paint supplier can likely mix those colors. I believe the local Smythe Auto Parts near me uses Sikkens paint or something, but the paint matched well when professionally painted.
Old Aug 23, 2017 | 07:24 AM
G2B35AGN's Avatar
I found my OEM B30 Lakeshore Slate escutcheon on amayama.com. I was able to ID the correct part number at infinitipartsdeal.com. See this post for the long version of my story: https://g35driver.com/forums/g-spot/...ml#post7114089
Old Aug 23, 2017 | 12:06 PM
sah302's Avatar
Hmm I can't find it there: https://www.infinitipartsdeal.com/pa...tml?PNC=80645M
It doesn't have the color. I even tried putting the missing numbers (like
80645-AM806) no dice onAmayana. I guess I am going to have to go to a prof painter, but that's going to be expensive dangit.
Old Aug 23, 2017 | 08:32 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
They have it in your color code here, another Infiniti dealer with an online shop.
https://www.infinitipartsonline.com/auto-parts/2004/infiniti/g35/base-trim/3-5l-v6-gas-engine/body-cat/front-door-scat
Part 5, dealt with these guys before, they're good. If you have any questions just call them and ask for the parts counter.
Old Aug 24, 2017 | 12:22 PM
gary c's Avatar
Since you need a new rear bumper (you'll never find one in your color) which will need to be painted, have the body shop paint the escutcheon too! Looking for a bumper in good condition check our Marketplace under Private Classified then exterior or your local Infiniti/Nissan bone yard. Their parts system can find anything...Gary
Old Aug 25, 2017 | 01:11 AM
G2B35AGN's Avatar
https://www.infinitipartsonline.com/...ront-door-scat
Yep, with that info helping to get the correct part number for your year and color, amayama.com has it for $17.38.
https://www.amayama.com/en/part/nissan/82646am816
So if you are not in a rush, you can get it cheap and it will come already paint matched....
Lordy I love the interwebs.
Old Aug 28, 2017 | 12:30 AM
sah302's Avatar
That's medium blue, mine is pearl blue. They are different.
Old Aug 28, 2017 | 06:46 AM
G2B35AGN's Avatar
It says it is color code B16. That's the important part. The words are just descriptive, not determinative.
Old Aug 28, 2017 | 11:10 PM
sah302's Avatar
I don't think so. Please see here: https://touchupdirect.com/touch-up-paint/infiniti-g35/
The code is B16, the part you link is 816. By that logic, the real medium blue should be 821, cuz it's code is B21, but that doesn't exist.
This is the medium blue g35: https://imganuncios.mitula.net/infin...7038898085.jpg
I'd be inclined to believe you and I could still be mistaken, but the part numbers are different (eight for B), or if there was no actual medium blue color for the car. But there is.
Old Aug 28, 2017 | 11:24 PM
G2B35AGN's Avatar
In that case I'd follow cleric's suggestion and call the parts counter at his link. I was just using their parts diagram to ID the part at amayama.com. Maybe it's a mixup in the diagram/descriptor. They can probably confirm the part number to the color. Then use that to do the look up on amayama. I'm just trying to give you a lead on where to find OEM parts at great prices. It's up to you to verify that it's the correct part. BTW that blue pearl is a nice color; much better to my eye than the medium blue.
Old Aug 29, 2017 | 12:26 AM
sah302's Avatar
Hmmm yeah now I am confused. That part he linked is the same number as the one you linked. the 816, but it does explicitly also say color code B16. I hope that is it, because then I can just order the super cheap one you linked. The only thing that gives me pause is its for 2004, I know they discontinued the blue pearl color, but I sure hope they wouldn't reuse the color code between years but have them be different colors. So a call I will do!
Old Aug 29, 2017 | 07:17 AM
G2B35AGN's Avatar
I think the B16 color code and the 816 part number is just coincidental. If you run down the list of #5 parts, it's a sequential number series for the various colors. I wouldn't fixate on that. Just get them to clear up the confusion between the color code and color name. Even if the B16 color piece turns out to be a different part number, once you confirm the number you can search for it at amayama. Also, you can enter your VIN at these parts sites and it will know your color and take you to the right parts (usually...sometimes the part sites aren't programmed down to that level of detail).
Old Sep 5, 2017 | 11:10 AM
hhinfiniti's Avatar
80645-AM816 is the correct part number for the B16 color code. I do show new stock available from Infiniti. If you'd like to check pricing check out our eStore at http://www.infinitiofhiltonhead.com/...arts-store.htm. Remember that you can use your G35Driver promo code for an additional 20% off the online price.
