G35 & G37, Coupes & Sedans
Was there ever any verdict on the fuel economy issues?
Old Feb 10, 2019 | 12:35 PM
  #31
Silversleeper86's Avatar
G35 Sport Sedan 5AT
Originally Posted by telcoman
Cruise control can lower MPG by 1 to 2 MPG because it needlessly automatically brakes the vehicle on downgrades. I stopped using it
Yes, it can lower, and like csw says it depends. And it's not because of the downgrades where CC can reduce overall MPG, it's the upgrades. If your trip is flat or mostly flat, like going through Kansas or traveling between Bay Area and LA, and you passionately keep CC on with little to no variation in speed, there is no way it's worse than your foot. Your foot is constantly on and off the gas a little bit here a little bit there
Old Feb 10, 2019 | 12:40 PM
  #32
G35 Sport Sedan 5AT
Originally Posted by jcd35
Did you ever get any solution?
I have the same issue on a 2003 coupe , auto, de motor.
No CELs
He says it was the MAF sensor a couple posts up. I've read that the non OEM/non Hitachi sensors are prone to failure. Which makes me think they could be prone to operating like crap when they are working. Check to see if it says Hitachi on your MAF sensor. Maybe even look at your cam sensors too
Old Feb 10, 2019 | 02:29 PM
  #33
gary c's Avatar
Subject: Fuel Economy!
Follow Nissan's recommended maintenance schedule and use 5W/30 Synthetic oil! If you have an AT D&F the trans fluid more frequently than what Nissan recommends...every 2 years especially in hot climates! To maximize your fuel economy make sure your engine is running at peak performance! (zero error codes) Use your cruise control whenever possible and block that sweet sound of your exhaust from your brain by turning up your tunes! Run 35 psi in you tires, check it every oil change! Don't be the first on to leave the stop signs as much fun as it may be!
Gary
Old May 1, 2019 | 01:42 PM
  #34
Fcknshauna's Avatar
G35
Obviously really late response, but I literally just FINALLY (after 2 years and thousands on parts and having Infiniti + various other mechanics try to find out the issue) figured out why P1283 wouldn’t go away and I’ve changed every o2 sensor and every a/f senors on the car & MAF as the most obvious culprits I thought)... Anyway I’ve been reading the threads on since I got my 04 G sedan 2 1/2 years ago with 170k, now it has 212k ... yesterday I randomly found an article that said to reset the ECU (I’ve done this only the battery way and the pedal dance) I was totally unaware the ECU has two fuses, take both of them out for 10 min and put them back in and ECU is completely reset. I thought I’d give it a shot instead of paying Infiniti $700 to fix it... I took both fuses out, BOTH FUSES WERE SHOT!!
I swapped them out and problem solved.. been over 100miles and still no CEL, and not to mention my MPG has literally doubled. I was just about to drive my G off a cliff too!
Old May 1, 2019 | 03:07 PM
  #35
Hall Stevenson's Avatar
Fuses either work or they don't work. There's no "not working optimally" or working poorly. What do you mean they were "shot" ? If both fuses were blown, i.e. "shot", your car won't run.
Old May 1, 2019 | 03:13 PM
  #36
Fcknshauna's Avatar
G35
Sorry, my verbiage probably isn’t up to par.. I stand corrected, one of these was probably still working which would explain why car was still running, but either way it was a simple fix.. hope this helps...!!
One on the right is the fuse that’s under the hood... replaced it with a slightly better one on the left.
One on right was fuse inside car.. replaced it with the one on the left.
Old May 1, 2019 | 04:13 PM
  #37
BULL's Avatar
HELL WHY NOT?
I'll be checking my fuses soon, I've exchanged many sensors. I've litterally learned resistance between cam and crank sensors, sealed intake manifold, measured injectors, measured and replaced coils along with upgrading the stalks. Changed an AF sensor and blahhh.
That is a weird issue. From what I can see it could be due to contamination (fuse boxes are not in an ideal location) or could be that it saw a period of high amperage, just not enough to burn it that it carbonized it.
Old May 1, 2019 | 04:37 PM
  #38
Fcknshauna's Avatar
G35
I’m still shocked.. keep driving in circles to see if it’s going to change.. only thing that changed was my MPG doubling & no CEL.. & the camshafts & crankshaft sensors... those were a whole different story. Hopefully someone else finds this info helpful! Good luck!!
I get it... sometimes it’s hard for certain people to believe anything a girl says about cars. Hahah
Old May 1, 2019 | 04:57 PM
  #39
As badly corroded as those terminals (?) were, yeah, that could cause intermittent or continuous issues.
Old May 10, 2019 | 11:08 AM
  #40
Urbanengineer's Avatar
It amazes me electrical connectors don't show up from the factory with dielectric grease in them. This is what the lack Thereof causes...
Old May 11, 2019 | 11:22 PM
  #41
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The IPDM was supposed to be a dry location though, however it turned out to have a very fatal flaw in the cover being difficult to completely seal up and the cowl drains were prone to getting clogged with debris.
Basically a perfect storm of engineering flaws, however I completely agree that aluminum bladed fuses should have anti-oxidation grease applied to them.
