G35 & G37, Coupes & Sedans
Window's roll down but not up, suggestions?
Old Feb 22, 2018 | 05:03 PM
LBail77's Avatar
Says it all in the title.
Old Feb 22, 2018 | 05:11 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Take off the door panel, unplug the window motor harness, grab your digital multimeter and see if it has power for both up and down at the harness. I believe polarity just reverses depending on up/down, verify by testing a functional window. If you have power then it's just the motor is fried.
Old Feb 22, 2018 | 05:14 PM
LBail77's Avatar
That's i first thing i did. Power is reading for both up and down but only the down function is operational for both my windows. If my motor is fried i'm going to be pissed just replaced it not even a year ago.
Old Feb 22, 2018 | 05:19 PM
LBail77's Avatar
Do you think it could be that my car is in accessory mode? and if i were to start it the windows would be able to go up?
Old Feb 22, 2018 | 05:51 PM
LBail77's Avatar
Also i have not power to my sunroof either.
Old Feb 22, 2018 | 06:04 PM
cleric670's Avatar
BANNED!!!
Fuse Block - J/B inside the cabin at the drivers left foot, check fuses 1 (top left) and fuse 18 (bottom row 7'th from the left), both are 10 amp fuses for the sunroof. I suspect your window motor is fried sorry, if you want to test it take the motor off and plug it in on the other door, I think the harness is the same but the motors are backwards.
Old Feb 22, 2018 | 06:21 PM
LBail77's Avatar
I suspect its a wiring issue and not my motor. Don't think that the motors on each door would go randomly at the same time considering there both pretty much brand new.
Old Feb 22, 2018 | 07:50 PM
cleric670's Avatar
BANNED!!!
Ohhh I misunderstood you, BOTH windows perform the same, that makes me think your BCM is going out since the signals all route through it. Probably going to require a trip to Nissan and a diagnostic to confirm.
ScraggleRock
Sep 20, 2017 10:55 PM
TRDseries
Nov 6, 2005 11:09 PM
SpX
Aug 10, 2004 12:03 AM
Wanchu83
Aug 5, 2004 12:38 AM
Dazzo
Nov 7, 2003 12:35 AM
