G35 & G37, Coupes & Sedans
Y Pipe hell
Old Sep 20, 2018 | 09:27 AM
anbeyond's Avatar
Y Pipe hell
Trying to change the Y-pipe in my 06 G sedan base. Anyone else have problems with the lower cat studs?
Old Sep 20, 2018 | 11:13 AM
Urbanengineer's Avatar
Heat em up! They sit at cat hot temps and you are trying to take them off cold.
Old Sep 20, 2018 | 11:25 AM
jbarnett250's Avatar
^^^ +1. My passenger side came off easily with heat. My driver side was so rusted that the nuts were rounded piles of rust before I started. I just cut them and pounded the cut studs out.
Old Sep 20, 2018 | 11:37 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Couple days worth of PB Blaster sprayed on them and an impact driver.
Old Sep 20, 2018 | 01:39 PM
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
Both sides of mine were so rusted I had to cut them off, however I wasn't able to pound out the remnants. I figured if I ground off the other side then that would take care of the rest, but nope, the remnants are still in the flange hole. Unfortunately I haven't had time lately, so the car has been sitting in the garage on stands for the past few weeks. :-(
What size hammer did you use to pound them out? I'm worried about damaging the cat flange or even the manifold.
The pic below is the mid to Y-pipe connection, but the Y to cats were about the same.
Old Sep 20, 2018 | 06:07 PM
Blue Dream's Avatar
I drove ttrank's car solo
^They say a picture is worth a thousand words and this kind of corrosion makes me happy I live in the south. That's some major BS right there.
Old Sep 21, 2018 | 06:17 AM
Scorpi0's Avatar
Holy corrosion!
Old Sep 21, 2018 | 09:52 AM
gonna sound cheesy but i used whatever 16 or 20oz claw hammer i had sitting around and could swing under the car on stands. i just lightly tweaked one side of the cat flange but just banged it back after the stud was out. i didn't know any better so i wasn't really scared before i started trying to pound them out. i couldn't back up the flange with anything so that's about the only choice i had other than paying somebody to do it.
Old Sep 21, 2018 | 05:38 PM
cleric670's Avatar
BANNED!!!
Cold chisels work great if you just want to take the studs off.
Old Sep 21, 2018 | 05:40 PM
cleric670's Avatar
BANNED!!!
I should add you need to brace the flange so it doesn't just bounce around. Stacking short cuts of 2x4 behind it till it's wedged tight against the floorpans has always worked for me. Little more precise than a sawzall blade on a rolled flange.
Old Sep 21, 2018 | 11:57 PM
coffeysm's Avatar
I used the a Harbor Freight ball joint separator to get those studs out. Cut the nut off and leave a good amount of the stud still on. Then you put the arm against the stud and the u portion between the head of the stud. They'll pop out and sound like a gun. After trying for awhile with various other methods, I gave this a shot and once I got it the first time; I got the other three out in 5 minutes.
Old Sep 24, 2018 | 10:10 AM
20 Year Member
Thanks, I'll probably try that next.
Old Sep 27, 2018 | 01:24 PM
20 Year Member
I ordered one for $20 through Prime on Monday. I used it last night and it worked exactly as you said. I'm glad I was wearing eye protection because they really do come firing out. Thanks for the suggestion!
Old Sep 30, 2018 | 12:17 PM
anbeyond's Avatar
Thanks guys for all the feedback. Sorry for the late reply. So after countless hours I finally got it out. I had to result in getting a cutoff tool from amazon for 20 bucks and a pack of blades for 7 more. Now its on to installing the new one. Got it from FRsport.com for 80 bucks. Hopefully it'll be worth it. Made by Manzo (I never heard of them lol).
Cone
Engine - Exhaust CDN
Sep 21, 2011 09:57 AM
Bnag0
Feb 25, 2010 10:47 AM
-G35-
Intake & Exhaust
Dec 15, 2007 01:37 AM
Kilrmy
Feb 19, 2003 03:42 PM
