G35 & G37, Coupes & Sedans
HELP. Cylinder 3 not firing!!
Old Jul 14, 2023 | 07:27 PM
croman's Avatar
G35 coupe
I'm guessing it's a wiring issue. Need to verify you have 12vdc on the white/blue stripe wire, ground on the black wire, and the third wire for cylinder 3 is a blue/red stripe that needs to go back to the ECM pin 61.
No, I already clarified that I have proper power, ground, and continuity to ECM on pin 61 for coil 3 connector. Nothing seems shorted either.
I recently started a new thread on this in G35 Coupe V35 2003-2007. I have measured the signal from terminal 1 on the connector (the connection to ECM signal) when it is misfiring and it is getting 0V whereas the other working connectors display a 0.2V square wave at idle.
With continuity but no signal, the only thing I could think is that the ECM would be having issues, however the strangest thing happens when resetting the ECM. The misfire disappears… not just the code, the actual misfire it seems. Cyl 3 will start firing and the car seems to be running normal, but after driving it for a bit the misfires resume, the spark drops off, and the car starts idling rough and throwing codes again. I was trying to determine if this is just a continued ECM failure, or if it is some kind of limp mode where the cylinder is shutting off to protect the TWC.
Very confused..
Old Jul 15, 2023 | 04:37 AM
Scorpi0's Avatar
Well it looks like u have a bad ECU then.
quanttrom
Mar 25, 2022 06:53 PM
Motohead1
Dec 23, 2021 09:20 PM
Sarah Kibler
Jul 10, 2018 10:31 AM
L36
Apr 1, 2013 07:44 PM
Cesar023r
12
Jan 10, 2013 03:36 PM
