Srs light
Srs light
I have a 2006 Infiniti G35 coupe I’ve fixed my car from a previous car collision I had a while back in 2021. Unfortunately, I have an SRS light on which I promptly replaced the SRS module with a used one from the previous generation (2003). The light was solid but now blinks in a sequence but I am having a tough time resetting the light with the reset procedure. The diagnostic mode tells me it’s either the RH side curtain airbag (which was also replaced) or the module itself from the consecutive SRS blinks (5 blinks). I checked the RH curtain airbag and its harness seems to be properly connected. Which component is causing the SRS light? Can it be the SRS module being non-compatible/outdated or a faulty RH curtain airbag? Possibly the crash zone/impact sensors but sensors are in front which are undamaged I only had a rear collision…
BaoDaLazi
Nov 6, 2013 11:02 PM
