G35 & G37, Coupes & Sedans
intermittent starting/cranking issue
Old Dec 23, 2023 | 12:41 PM
Thirtyfaa's Avatar
2003.0 5at sedan
hello all, looking to see if i can possibly get help trying to get my 03 sedan to start reliably.
last week my starter went out (atleast i think) and i replaced it yesterday and the car started 3x after i lowered it on the ground and around 20 minutes later after i put the jack and tools away and went to move the car back to its spot from where i lifted it and nothing. just a single click just like it was doing before i replaced the starter.
after repeatedly turning the key a couple times i got it to crank and turn over just fine to move it back and turned in off again and tried to start it and back to the click
got it to start one final time before leaving it alone although this time i did hold the key for around 5-10 seconds in the start position after it clicked and the car cranked and started so not sure if that means anything
the cars has had intermittent starting problems for the past year or so but it’s never not started, i would always just hear a loud kind of grind/screech but i would just turn the key back and usually it would just start the second third time varying.
to name some things i recently replaced not even a month ago
coil packs (hitachi)
spark plugs
cam sensor(hitachi) and connector pigtail
vvt selonoid (hitachi)
and the battery is only about a year old aswell
throughout all of this from it originally going out and since i’ve replaced it the car hasn’t thrown a single code either
if anything could provide any insight or help it would be really appreciated and if anyone has any other questions let me know
thanks
Old Dec 24, 2023 | 10:22 AM
Mr.GEE's Avatar
20 Year Member
Check the ground connections for corrosion. Make sure the battery terminals are clean and properly tightened. Have the battery checked. Sometimes, even new batteries can fail. Also find and check the starting relay. You can find the factory service manuals at https://www.nicoclub.com/infiniti-service-manuals. They are free.
theredphoenix
Aug 24, 2024 04:05 PM
Xavier g35
Mar 3, 2023 09:14 AM
RedG35Az
May 14, 2014 10:03 PM
Mr. G
Nov 10, 2013 11:38 PM
tcpombomb
Dec 18, 2011 06:41 PM
