G35 & G37, Coupes & Sedans
Plenum Spacer Install, Help!!
Old Oct 24, 2005 | 02:35 PM
josephsuiskind7's Avatar
Originally Posted by Hydrazine
That certaintly could cause stalling... but smoke???... I don't know where that comes from.
How flat was the spacer? Did you get a good look at it?
what do u mean by "how flat was the spacer?"
its a 5/16th" spacer if thats what ur asking..... l
let me try it again, should have time tomorrow i hope
Old Oct 24, 2005 | 02:42 PM
z_with_back_seat's Avatar
Originally Posted by josephsuiskind7
Got A Plenum Spacer The Other Day For My Sedan.. Tried Putting It On, Seems Like A Pretty Simple Install But Followed Instructions That Came With It Anyway. After Everything Was In Place And Put Together With The Plenum Installed.... I Turn On My Car And It Has Extreme Trouble Staying On, Idled Really Low And Shook Abnormally, There Was Also Way Too Much Smoke Comin Out My Tail Pipes...
I Checked To Make Sure The Rights Size Bolts Were In The Right Holes And All Tightenned Properly And Put In, In The Right Order... Still No Luck.............anybody Have Any Ideas???
Now I Have It Back To Normal But Would Really Love To Have This Thing In!! .. Somebody Help Me Out. So I Dont Have To Return The Spacer....
If you have an aftermarket Cold Air Intake it is possible to reinstall the Mass Air Flow Sensor backwards. The rasied triangle near one of the ends should be facing towards the back of the car / direction of airflow.
That or the spacer has a leak in one of the seals. Check in the front drivers side of the spacer. Is it hitting the large mounting bracket for the wire loom?
It is also possible the the rubber collar around the Oil Cap might be caught between as well.
Those are my 3 guesses . . .
Good luck!
Old Oct 24, 2005 | 04:38 PM
Hydrazine's Avatar
If you got it from gruppe-s.com its not 5/16" spacer unless sombody is copying my design. If they are, they will hear from my patent attorney.
You are probably thinking of the 5/8" plastic spacer from Skunk2. gruppe-s.com sells them.
Old Oct 24, 2005 | 07:28 PM
nah they do sell Skunk2 Plenum Carbon Composite Spacer - 03+ 350Z
for $225, but i bought their AAM angled plenum spacer .. its aluminum, not plastic
Old Oct 26, 2005 | 02:11 AM
tryin to reach gruppe-s so i can return the spacer and get it from motordyne they seem more reliable either way, written 2 emails already and no response... can anybody vouch for gruppe-s?
Old Oct 27, 2005 | 07:18 PM
Success With The Install!!!, Would Never Buy From Gruppe-s Again... My Mistake For Not Goin With Motordyne
JMFeld02
Intake & Exhaust
Feb 25, 2016 07:50 PM
CoupeObsession
Aug 17, 2015 01:05 PM
Raven7
Aug 14, 2015 04:40 PM
deathsupport
Canada
Aug 2, 2015 10:13 AM
