G35 & G37, Coupes & Sedans
Paint Splash Effect :(
Old Feb 11, 2006 | 06:39 PM
dennis_said's Avatar
I was driving on the freeway and there was a split can of paint... I drove over the paint and had it splatter across the side of my car... when I finally arrived home, the paint has dried.
There are splat marks every where... I can remove it if I scratch it off w/ my fingernail but it has to be excessive scratching (really tough)... is there a solution to this?
THanks
Old Feb 11, 2006 | 06:48 PM
Diesel1's Avatar
Moderator
SHould have posted in detailing forum but anyway, get yourself a good clay bar, maybe even 2. I would advise to try an autobody supply house as they have clay which will remove overspray and harsher particles. The over the counter stuff from Pep Boys probably won't be as effective or will take a long time. Afterwards you will need to polish the paint an dseal it with a good wax or synthetic sealant.
Old Feb 11, 2006 | 07:11 PM
riffraff's Avatar
sorry to hear bout that. what freeway was this dennis?
Old Feb 12, 2006 | 12:38 AM
accordfreak's Avatar
try clay bar.
Old Feb 12, 2006 | 03:49 AM
I will try claybar and hope that it can penetrate the paint... gives me a chance to detail the car I guess haha
Old Feb 12, 2006 | 03:51 AM
madchef's Avatar
Wow that's terrible
If it was my car, I would strip down all the wax (dawn) and really get into the paint to remove it (via maybe a cross pattern towel). Then claybar (make sure its lubed), then redo the wax.
Good luck!
Old Feb 12, 2006 | 11:10 AM
I was thinking the same thing madchef =) RiffRaff it was on the 91
Old Feb 12, 2006 | 11:29 PM
ZLUJ's Avatar
Mmhm...
damn that sucks, what were you thinking in your head when you were driving up on the can ?
Old Feb 12, 2006 | 11:47 PM
did you use clay bar yet? the longer you wait, the harder it is for it to come off espcially in so cal's 90degree weather
Old Feb 13, 2006 | 05:32 PM
kidtronix's Avatar
Optional
Clay bar or a body shop to pull it off. Should look fine afterward. If youre doing it yourself, the key word is PATIENCE.
Regards,
Axl Rose
Picture Share
Feb 4, 2018 12:41 PM
DRG35R
Jan 31, 2016 07:14 AM
