G35 & G37, Coupes & Sedans
Best way to remove 3M DOUBLE SIDED ADHESIVE?
Old Mar 18, 2006 | 10:45 PM
dennis_said's Avatar
I have the red tape adhesive from 3M, I used quite a bit of it to install my INGs face ducts... I actually want to remove the face ducts now to paint them... what is the best way to "PRY" them out? Is there a solution that will just release the hold from the adhesive?
TIA.
Old Mar 18, 2006 | 10:51 PM
firefox's Avatar
Usually if you heat it up with a hair dryer, it loosens the adhesive up.
Old Mar 19, 2006 | 11:37 AM
I'll definitely give that a try, thanks firefox
Old Mar 19, 2006 | 03:28 PM
Real_G's Avatar
An Army of One...
GooGoo Gone I think its called.. they sell it at walmart.. I used it to remove sticky residue from where I had a rug 3M taped down to keep it in place at my doorway at home.
Old Mar 19, 2006 | 03:30 PM
GRider35c's Avatar
use a heat gun to pry it off, then use GooGone or GOOF OFF... it will just melt the leftover glue, use a lint-free towel and rub in circles to turn the leftover glue into a ball, then take the ***** of glue off with your fingers...
Old Mar 19, 2006 | 11:19 PM
daveblank's Avatar
Don't pry on them. Use fishing string like dental floss to cut the tape. Then use Goo Gone to get the tape off the body & the ducts.
Old Mar 20, 2006 | 10:22 AM
GT-Ron's Avatar
Repeated applications of Goo Gone will take care of the adhesive residue without trashing your paint. You won't get it in one shot, so be patient.
Most importantly... ...WATCH WHAT YOU USE TO APPLY IT! Made-in-the-USA, 100% cotton towels (not Egyptian, Pakistanni, etc.) will be soft enough. Same towel requirements used for waxing.
Old Mar 20, 2006 | 05:46 PM
97supratt's Avatar
Just heat it up with a hair dryer and use fishing line to get it off with no scratches.
Old Mar 21, 2006 | 12:17 AM
Otacon132's Avatar
can this be done also to remove door guards?
Old Mar 21, 2006 | 09:33 AM
Efiniti's Avatar
And emblems...
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Oregon13
Mar 1, 2016 12:06 AM
