G35 & G37, Coupes & Sedans
Show me your hockey pucks!
Old Oct 28, 2008 | 11:37 PM
  #31
Beebo's Avatar
Originally Posted by OCG35
why do you guys need a pad?... I just line up the jack and lift - never had a problem.
^+1
Old Nov 22, 2012 | 10:40 AM
  #32
CaptCoolio's Avatar
I used a router and a 1/2" stright bit, it is not perfect but worked like a charm. I need to make something that will hold the puck so I can make a better cut. Straighter cut
It worked flawless last night on the G35X to install the winter tires
The puck was 99 cents 20 mins to router, worked like a charm=priceless. Not to mention no damage to the body.
Old Nov 26, 2012 | 08:15 AM
  #33
Mustang5L5's Avatar
Ouch. Please tell me you guys aren't just working on cars supported by Jacks only? All it takes is a bump or a seal failure for the jack to crash down.
Use a jack only to get the car on jackstands, and that's is.
Old Nov 30, 2012 | 12:35 PM
  #34
Q451990's Avatar
Always worth a reminder on that point...
I'm talking about using these on the jack stands, since the owner's manual or service manual (can't remember which) shows the lift points/jack stand points to be on the crease under the body - which will crush down if you just sit it directly down on the jack stands.
I haven't found that the groove is critical... the ridge just pushes down into the rubber. With that in mind, I think I'd skip cutting the groove just to avoid weakening the hockey puck.
Heath
Marlin84
Apr 1, 2020 12:52 PM
master111
Oct 6, 2015 01:36 AM
