G35 & G37, Coupes & Sedans
Loose Cone Filter - Damage?!!
Old Apr 19, 2006 | 01:28 AM
irshadow's Avatar
So, today I was checking my oil...and then checking my intake to see if its all good. I found that the filter was a bit loose. I think the weather here might have loosened it up a little bit. Do you think there might be possible engine damage? Or will the oil filter, filter it out? I was wondering what happened to my power, until I retightened it. I just hope everyhting is ok.
Also, there is a hissing noise coming from the left side of the engine. Normal? I was all paranoid about my car after finding the above.
as;lfkdja;lskdfja;lksdjf
Old Apr 19, 2006 | 01:35 AM
Strtsk8r321's Avatar
its possible that it was rubbing against the ac line. A/C still cold?
Old Apr 19, 2006 | 09:47 AM
irshadow's Avatar
a/c is fine...i protected my a/c line. Its just from the hot weather i think the filter got loose. I'm just worried bugs or some crap went in thru the throttle body./
Old Apr 19, 2006 | 10:59 PM
obender66's Avatar
Have an oil and filter change. Whatever got sucked in is in your oil/filter now.
I wouldn't worry too much, oil filter should capture that dirt.
Bugs will do no harm, they are soft and crunchy
Marlin84
Apr 1, 2020 12:52 PM
DRG35R
Jan 31, 2016 07:14 AM
prinny
Nov 22, 2015 11:07 PM
dcsbh1
Oct 1, 2015 03:15 PM
