G35 & G37, Coupes & Sedans
farily new here, possibly some noob questions
Old May 1, 2006 | 09:34 AM
timdastis's Avatar
hey guys i recently got my 03 6mt g35 and so far im loving it...this is my first manual car so its definatly alot more fun than my previous accord v6
anyway i got a couple questions that r prob a bit noobish, i tried searchin but couldnt find much
1st - what number bulb is the clearance strip light? how do u get to it to change it?
2nd - with HIDs, if i wanted to upgrade to a more blue or more white, would i have to upgrade my entire hid kit, or could i just get the certain xxxxK bulbs?
3rd - how do u spin ur tires and do a burnout? i know i turn off vdc and ive been able to slide around in a parking lot, but how do u just stay in one spot and spin ur wheels?
thanks for the help
heres a pic of my ride
Old May 1, 2006 | 10:41 AM
some.devil's Avatar
COngrads and welcome...
1. in the sedan the clearance lights for the 03.5 are 194/168 wedge bulbs
2. if you have HIDs then you just need to get different bulbs
3. tires are too expensive to burn!
Old May 1, 2006 | 02:35 PM
IvoryGT's Avatar
1, 194 bulbs, you remove the front wheel well by turning the steering to the outside and reach and remove the clips. then you will see 2 wires running up to where the clearance strip would be, just turn it counter-clockwise and change out the bulb.
2. for whiter or blue, get 5000K D2R bulbs or any other temperature that is D2R. I suggest doing some research about bulbs and color temperature before you do.
3. hold the RPM to around 4900 and release the clutch just enough to start spinning...obviously this is both bad for your tires and clutch. But if you just want to launch the car. 3500rpm and dump the clutch is a good place to start.
Kng0fHrts
Sep 15, 2015 05:40 PM
mrxkenny
Aug 17, 2015 05:52 PM
as25656800
Aug 9, 2015 07:25 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
