G35 & G37, Coupes & Sedans
octane
Old May 8, 2006 | 07:58 PM
swoop's Avatar
octane
Just purchased my G and am putting super unleaded in it, but i have heard rumors that the engine was designed for regular.
Anyone have any insight?
Old May 8, 2006 | 08:06 PM
mephistomyhero's Avatar
Just put in what the manufacturer says: Premium unleaded. You did buy $37K car, why put regular in it?
Old May 8, 2006 | 08:09 PM
Mr. Wonderful's Avatar
That's funny.... my owner's manual says to use regular in my sedan.
Why waste money filling it with premium if it doesn't need it ?
Maybe the coupe needs premium ?
Old May 8, 2006 | 08:28 PM
Chrlesmd's Avatar
The owners manual actually does specify premium unleaded. I think it also says to use regular only when necessary until you can fill with premium. I imagine it wouldn't run well on regular gas, ping maybe.
Old May 8, 2006 | 08:32 PM
SDG's Avatar
SDG
My 03 says on the lid, Premium Fuel ONLY. On the new Coupe it says, "Recommended"
Interesting, why the change?
Old May 8, 2006 | 09:05 PM
Andy2434's Avatar
With regard to my car and the '05 Owner's Manual . . . It reads . . .
*Sedan - Automatic Transmission models . . . Use unleaded regular gasoline with an octane rating of at least 87 AKI (Anti-Knock Index) number (Research octane number91).
For improved vehicle performance, Infiniti recommends the use of unleaded premium gasoline with an octane rating of at least 91 AKI number (Research octane number 96).
*Sedan - Manual transmission and Coupe models . . . Use unleaded premium gasoline with an octane rating of at least 91 AKI (Anti-Knock Index) number (Research octane number 96).
If premium gasoline is not available, unleaded regular gasoline with an octane rating of 87 AKI number (Research octane number 91) may be temporarily used, but only under the following precautions:
- Have the fuel tank filled only partially with unleaded regular gasoline, and fill up with unleaded premium gasoline as soon as possible.
- Avoid full throttle driving and abrupt acceleration.
However, for maximum vehicle performance , the use of unleaded premium gasoline is recommended.
Caution: Using a fuel other than that specified could adversely affect the emission control system, and may also affect the warranty coverage.
Under no circumstances should a leaded gasoline be used, because this will danage the three-way catalyst.
Old May 9, 2006 | 02:56 AM
Damn Andy, how long did it take you to type that? Oh, I guess I forgot to specify I have a 6MT coupe, so yeah, Premium. My guess is that us 6MT drivers tends to rev higher I guess in Infiniti's engineers mind
Old May 9, 2006 | 06:31 AM
badtz's Avatar
My question is that if you use 100 octane fuel would you feel a power gain over using 91 octane?
Old May 9, 2006 | 08:31 AM
JaxGman's Avatar
Nope... u wouldnt, only way you get more power using 100 octane would be increasing your timing, which the higher octane would allow you to do.
Old May 9, 2006 | 10:13 AM
96max2fast's Avatar
If its a lease, who cares!!!!
Old May 9, 2006 | 09:00 PM
swoop's Avatar
Thanks for all the info. ill stick to the high octane with the 6mt.
g.spot
May 9, 2016 10:54 PM
bigmike
Sep 17, 2015 01:58 PM
Fire0nic3
Sep 1, 2015 12:12 PM
