1/4 mile track time
yeah man, great run, maybe next time you'll get into the 15's!!! the higher the better, right? well, since your only running stock (didn't we install a spacer in your car) then the only way to go now is up... Dipset Bitch!!!
Originally Posted by Hanz
What's the settings?
As far as Tire Pressure, What were you revving at?
W/ My teg before i had tire pressure at 19psi. made a huge difference. I went from 14.5 to 13.79 @ 7lbs boost
... and i reved upto 6.5krpm and power shifted..nex time i'll work with the tire pressure.. also might have better time with new tires instead of the worn out set i have on now...
joel extreme
SOCAL Meetings & Events
Jul 23, 2015 04:13 AM
quickspeed6
24
Jul 15, 2015 11:06 AM
