oem aluminum pedal
Old Oct 22, 2004 | 02:09 PM
Diesel1's Avatar
Moderator
Re: oem aluminum pedal
Very Easy!! Grab a bucket of hot water and throw the break n clutch pedals in em for a while to soften the rubber. Remove the stock pads, takes a little um "finessing". The new ones slip over, I did mine by using 2 flathead screwdrivevers to work the lip of the pedal over the METAL pedal attached to the car. Gas pedal is fairly simple, crawl unde rthe dash and take a look at the clip, u'll see how to disengage it. Ur new pedal has a clip too. When u get the stock one off, slap the new one on with the new supplied clip and ur good to go.
Dead pedal, i forgot exactly but there is a big slot that you turn to disengage the dead pedal from the floor, fuss with it a bit and pull that fu.....sucker off. New one install via reverse instructions!
It's pretty self explanatory once u get in there. Only tips i knw is either a hair dryer or bucket of water to soften the new pads. FYI - Don't use both!!! It would be hairr aising!!
www.gsquad.org
Old Oct 22, 2004 | 02:29 PM
G35scBkNy04's Avatar
G SQUAD
lol..........very comical yet helpful post......thanx Drew
Old Oct 22, 2004 | 06:31 PM
Diesel1's Avatar
Moderator
Sorry, lil punchy today!!! Kinda OD'd on Zaino last nite!
www.gsquad.org
Old Oct 26, 2004 | 09:57 AM
G SQUAD
lol....Drew your instructions were right on the ball.....the pedals came out great...I luv the look it gives...goes great with other "aluminum" lol touches within the interior
Old Oct 26, 2004 | 07:39 PM
pezzonovante's Avatar
congrats drew...the first step is admitting you have a problem!
Steve
G-Squad Hi-Res Gallery
Old Oct 27, 2004 | 09:54 AM
G SQUAD
lol Steve
Old Nov 22, 2004 | 12:54 PM
G SQUAD
oem aluminum pedal
also got my aluminum pedals from performance nissan...how do i install them??? thanx
11bEMT
May 27, 2022 03:13 PM
