F/S: 2005 g35c Built motor with Vortech
Old Jun 17, 2008 | 01:28 AM
Mr_pharmD's Avatar
Please pm if interested... new setup.
Old Jun 17, 2008 | 02:01 AM
anDross's Avatar
very very nice.. gl with the sale
anDross's Avatar
Old Jun 17, 2008 | 02:17 AM
Beebo's Avatar
Great looking G... G/L with the sale... you may want to put up some pics of the rear and interior as well...
Old Jun 17, 2008 | 09:57 PM
Mr_pharmD's Avatar
Thanks for the kind words guys. Ill get more pix when I have time later this week.
Old Jun 17, 2008 | 10:00 PM
express705's Avatar
good luck with my new valve cover.
Old Jun 18, 2008 | 01:49 PM
serturbo's Avatar
Please post pics up if you pick up your new ride. The new M3 is so hot!
Old Jun 21, 2008 | 04:47 PM
Mr_pharmD's Avatar
28K without RIMS, Vortech setup, gauges, hi flow cats, and spacers. Bascially giving away a BUILT MOTOR at this price.
I also have the snow performance meth kit stage 2 that I havent got a chance to install yet if needed.
Old Jun 22, 2008 | 04:08 AM
Blackmouf's Avatar
Would you be interested in a trade for stock front and sides + cash. I have a OB coupe and my parts have no chips or dents. Send me a pm if interested.
Old Jun 22, 2008 | 04:09 AM
Blackmouf's Avatar
If you cant, just the nismo front would be fine
Think about it!!!!
Old Jun 23, 2008 | 04:02 AM
Blackmouf's Avatar
Im guessing thats a no?
Old Jun 23, 2008 | 01:53 PM
jouvert00's Avatar
What type of numbers are you putting to the wheels?
Old Jun 23, 2008 | 07:45 PM
Mr_pharmD's Avatar
440whp on a conservative tune when the new motor was installed. I havent gone back to get a final tune bc I want a few more stuff so the labor is cheaper. All I want was 450whp when I'm done but it could ezly see more then that once finished.
Old Jun 23, 2008 | 08:59 PM
itpro2002's Avatar
Seems real low for 16psi
Old Jun 25, 2008 | 02:33 AM
Mr_pharmD's Avatar
Like I stated before, 440whp on a conservative tune when the new motor was installed. It was never dynoed after that (~4months ago).
I havent gone back to get a FINAL tune bc I wanted a few more stuff added onto the motor so the labor would be cheaper to install all at once.
This was done on a DD dyno NOT dynojet so the readings are lower by ~12-15%.
Also I had barely any timing added to the car bc I wanted to make sure everything was running perfectly before I went for big numbers. As of now, there was only 14 degrees of timing total at WOT where stock runs around ~20-25 degrees. I believe each degree of timing u add will net about ~10hp. So if u do the math, 20 degrees of total timing (or another 6 more degrees) at WOT would net at least an extra +50hp. Note this was done on 91 oct in CA.
