2003 g35 coupe 116,xxx, Massachusetts
Feb 20, 2016 | 02:35 AM
2003 Infiniti G35 Coupe
Transmission - 5 speed automatic / tiptronic
Color - Laser Red
Mileage - 116,xxx
Located in Worcester, Massachusetts 01603
Works done within the past 16K miles and have receipts for most of the work done.
- spark plugs
- serpentine belt
- New oem transmission pan & transmission flush
- rear differential fluid flush(Limited Slip Differential aka LSD)
- Front lower control arm bushing (replaced with whiteline bushings)
- wheel bearing (both driver and passenger sides)
- front and rear sway bar links
- front and rear brake pads
- slotted and drilled rotors
- brake fluid flush
- Recent Oil Change as well. (Always used Mobil 1 full synthetic since I bought the car)
- oem rear camber arms
- Like new snow tires.
most services were done by a nissan tech from a nissan dealership.
Aftermarket add-ons
- roof spoiler
- HKS Coilovers
- Tinted windows (could be re-tinted)
- Kenwood Double din radio
- Aftermarket Y-Pipe
- Aftermarket test pipes
- 06-07 g35 tail lights
- JWT Hi-flow pop-charger intake
- Stillen Intake Pipe
- SPPC Headlights
- Compustar Remote Starter
No check engine light at all!
Cons/Bads - driver seat rocks a little (common issue for 03-04 years). washer fluid sensor needs to be replaced(cheap fix). clunking noise front suspension (needs new compression rod bushings recommend buying whitelines bushings).
Other then the cons/bads, engine and transmission runs great and strong, with no issues at all.
$7,000 or best offer
Title in hand - Clean title.
Can provide vin number.
Feb 24, 2016 | 07:06 PM
Glws
