FS: 2005 Infiniti G35X
Old Jun 15, 2019 | 09:59 AM
VstyLe09's Avatar
Smile 2005 Infiniti G35X
The good:
- Rays OEM 19 inch g35 coupe wheels (powder coated to match car) with Continental Extreme Contact DWS06 all-season tires. Used for about 2-3 years, all-year round. I would say still has alot of life left. The wheels and tires are all the same size which is good so you can rotate them every few thousand miles.
- Radiator, both ac and pulley belts just replaced a few months ago by shop
- Coolant flushed by shop
- Oil changed a few months ago by me
- interior is still good
The bad:
- Left Hood latch is cut to be able to close hood
- right O2 sensor needs replaced which is probably causing the check engine light
- I believe the right lower ball joint needs to be replaced
- left and right side markers are off due to rust (but can be screw-tapped back on)
- fuel gauge is failing
- head gasket needs to be replaced due to radiator cracking and thus overheating of the vehicle this past winter
- if driven now:
- the car makes alot of noise due to the ball joint being broken on the right side
- there will be white smoke, and you can even smell it, due to head gasket needing to be replaced
If interested, please text me at 708315fortyten
I'm in the Illinois 60517 area code.
Old Jun 15, 2019 | 12:00 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Confirmation pic required as per marketplace rules.
https://g35driver.com/forums/private...rules-106.html
Saaif88
Aug 29, 2017 08:15 PM
imad1986
Aug 2, 2012 03:07 AM
SqueakyClean35x
Apr 6, 2012 08:16 PM
dch
Oct 24, 2009 09:39 AM
KEVIN97A4
Apr 4, 2005 10:42 PM
