Anybody know if there are replacement oem clear guard wheelwell area, part number price? One of mind got ****ed by a big rock.....
Check the dealer... its cake to put on with soap/water and a decal squeege.. dont know how much it is.. but it cant be much
thanks---it's just really some abrasion that looks like the plastic rubbed off--but It doesn't look so bad, so I'm hoping when I take it off-there is no damage to the paint/bodywork....keeping my fingers crossed....
im sure your body is fine.. even though i have no idea how bad it is... that clear stuff is pretty tuff... o ya when you take it off there might be some sticky residue... i know some guys that used Stoners Tar/Bug remover when they debadged... i believe its clear coat safe (it should)...but you should give that a shot
I'm pretty sure this is the OEM part you're looking for -- for some reason the illustration isn't showing up for me: Stone Guard
One of mine is pretty bad also. If those are the correct parts/numbers, then those are nice and cheap. Easy to put on to.
Thanks guys! dealer had them in stock and they are pretty tough--no damage to the paint/body work
And my car is in the shop getting mrev2 and 5/16 spacer install
Jonnylaw...
How much were those pieces? Does it include the upper and lower part meaning the little sideskirt piece?
All I got was the upper piece and the dealer charged $14 for it, but put in on properly at no charge.Originally Posted by Disco_Monkey
Jonnylaw...How much were those pieces? Does it include the upper and lower part meaning the little sideskirt piece?
