DIY Oil Change for lowered Car?
Old May 23, 2006 | 02:24 PM
FI'ed G's Avatar
Ok, no places wanted to take my car so I had to go to one of those Car Was/Lube places that has an underground passage to get my oil Change (had my own Oil Filter) I have a mild drop but with the ING+ Front Lip and Side it is almost impossible to run this on a Ramp. I purchased a Jack that is perfect for lowered car (3" Min.) and my side skirt is about 4" off the ground. How do you guys change your Oil?
Old May 23, 2006 | 02:43 PM
Blackbird V35's Avatar
drive it up on some 2x4's then i use the jack
Old May 23, 2006 | 03:32 PM
Disco_Monkey's Avatar
^+1
The 2x4 will only lift it enough to get the stock jack underneath with those INGS sides. Use the stock jack to get it high enough to get the floor jack underneath the front black metal bracket between those two circles in the center. Lift the whole front then place jackstands. Do all of that in reverse order to lower.
Old May 23, 2006 | 03:33 PM
FI'ed G's Avatar
So you just jack the car? Jacking the car is not a problem since I have a low profile jack. It's more on the safest way to jack the car so I can change my Oil Filter and drain my Oil.
Down_Shift's Avatar
I went to Homedepot. They had a special on alot of their long planks of wood. So I bought about 12 of them.. And I nailed them one by one to create steps. I drive my car up the steps one by one.. Till it's about 2 ft tall.. Then I can do whatever I want.. Jack it up higher or just get under it.
It's a tight squeeze, but I can get under the car and get the underpanel off.. and do the oil change without jacking the car up.
I just did it again a few days ago.
I can't get any jack under my car since my car is so low with the kit. The only jack point I even have a chance to getting to is the rear diff.. And that's with a racing jack.
If you have access to a lift. I do the samething with blocks of wood.. except I only do it enough to get the lift arms under the car. (around 3 steps of wood)
Old May 23, 2006 | 08:09 PM
afr0puff's Avatar
Supa Dupa Moderator
I make draw of what I do. With my Nismo front, I just barely clear it. I'd be scraping if I was down to 34 PSI.
I was recently denied service at my local Infiniti dealership cause of the kit + drop.
Old May 23, 2006 | 10:27 PM
FI'ed G's Avatar
I was thinking the same thing. So having the car tilted like that will this drain all the oil?
Old May 23, 2006 | 11:40 PM
infg35's Avatar
Yes it will drain. I use 2, 3/4 " pieces of plywood with the rhino ramps. Did oil change 2 days ago.
Old May 24, 2006 | 12:12 AM
afr0puff's Avatar
Supa Dupa Moderator
The hardest part is getting the damn cover out of the way. I don't bother undoing all 16 of those bolts. Just the four inner body ones and then I fold it like the Infiniti techs do. Only problem is, there is barely enough room to fold that sucker down as it is. Such a PITA!
Old May 24, 2006 | 12:52 AM
mondo's Avatar
The oil change place I went to had some planks and I only pulled in far enough for the front end to be over the pit. They seemed used to this.
Old May 24, 2006 | 02:42 AM
truplay8's Avatar
THE BATMOBILE
i always have a problem jacking up my car cause of the damn ings kit........and im on stock suspension!!!!!
Old May 24, 2006 | 10:29 AM
FI'ed G's Avatar
even after the drop I had no problem finding a shop for the alignment. After the Kit was installed now there's no shop that will take it. even my old shop that use to take my previous slammed cars.
Old May 24, 2006 | 10:56 AM
lalomarquez13's Avatar
i used my home garden 2" concrete stepping stones...i was "desperate".... but once i was on them, i was able too get my jack underneath, im 3 3/4" off the ground....after that i just jacked it up on top of my rhinos....i did this last week it works great! and feel great knowing that im putting my own mobil 1 motor oil
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
NemesisGee
Aug 11, 2015 07:10 PM
ghost_g35
Aug 7, 2015 10:31 AM
ClwMike
Jul 23, 2015 12:55 PM
newbdriver01
Jul 15, 2015 06:10 PM
