Double-Din Conversion qustion !!
Old May 28, 2006 | 03:42 PM
alhamili's Avatar
Exclamation Double-Din Conversion qustion !!
Hi if I want to install the Double-Din Conversion do i have to buy the
1- Double Din Finisher
2- Double Din Bracket
3- Double Din A/C Control
thanx....
Old May 28, 2006 | 04:22 PM
mrjonang's Avatar
Yes you need the bracket and the a/c control when you go with a Double Din
Old May 28, 2006 | 05:17 PM
patman530's Avatar
bracket is optional if you have an 05+, you may have to drill holes into your existing bracket, which is not a big deal. I just had a avic-z1 installed in my 05 and did not need the bracket
Old May 28, 2006 | 06:28 PM
jerjerboy's Avatar
if u have a single din HU, do u still need the AC control???
Old May 28, 2006 | 06:56 PM
patman530's Avatar
You will still need the AC control if you go Single DIN. This is because you still have to remove the OEM finisher/HU+changer, and that is part of the same unit as the AC control, you can't separate them. In effect, it would be pretty much the same as doing a Double Din conversion, except you will have to find something to fill the hole. They do not make a finisher for Single DIN so you will have to put some kind of cubby hole in there. IMO, Double Din our cars looks a lot cleaner.
Check out this thread if you want to go single DIN: https://g35driver.com/forums/showthr...ght=single+din
Old May 28, 2006 | 07:51 PM
Oki-the-Nawa!'s Avatar
but i will tell you this, you overall do not need the bracket. I got mines changed without it. the ******* place forgot to replace it with the one i bought!! i have an ugly gap, but overall it worked. ac control and finisher absolutely. now i have an extra bracket i dont need. that works i assume.
Old May 29, 2006 | 05:09 AM
alhamili's Avatar
thank you all
Old May 29, 2006 | 02:43 PM
vodkarocket's Avatar
Modded Member
I've got a brand new 2005 double din finisher and double din bracket for sale- see my sig for details.
Marlin84
Apr 1, 2020 12:52 PM
Extreme Dimensions
Exterior-Vendor
Oct 29, 2015 10:24 AM
twentyeggs
Sep 11, 2015 03:58 PM
06G35Kurtis
Aug 23, 2015 12:24 AM
avalino
Aug 6, 2015 01:42 PM
