Rear Suspension Assy - Tunnel Stay
Old Jun 1, 2006 | 06:38 AM
Gashed's Avatar
So I just discovered that my tunnel stay on the rear right of the vehicle has been bent significantly, into the gas tank infact. I think when I went to get my tires replaced the f'd it up (please stay away from All About Tires in Toughkenemon, PA). At any rate, is this something I need to worry about? I don't know enough about cars to say.
Thanks.
Old Jun 1, 2006 | 12:11 PM
Gashed's Avatar
Maybe this pic will help - the tunnel stay is at the bottom and I circled the part that is bent up.
Old Jun 1, 2006 | 12:20 PM
Jellysick's Avatar
I dont know THAT much about cars either, but that cant be good... If it were my car, they would be paying to have it replaced.
Old Jun 1, 2006 | 12:24 PM
Msedanman's Avatar
O.F. Administrator
Thanks.
Since the brace has been bent into the gas tank, you should have Infiniti check it out for an unsafe condition and repaired as needed.
You may not have a leak at the moment but it could worsen with time and eventually cause a leak and fire.
Then you need to talk to the tire outfit who may have done the damage to see if they'll help.
G/L
C.
Old Jun 1, 2006 | 12:31 PM
jetblackg35's Avatar
We just replaced one here at Inskip Infiniti, one of the techs was doing the gas recall when he discovered that the stay tunnel was bent real bad.
Part #74870-AM800 $183.10 The price is not the bad if the delership you take it to wont replace it.
Old Jun 1, 2006 | 01:00 PM
Gashed's Avatar
That's good info jet - thanks much!
rezendvous420
May 31, 2020 01:26 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
ScraggleRock
Aug 11, 2015 10:16 PM
wuppiedog
Aug 7, 2015 11:16 AM
atk08
Jul 30, 2015 03:12 PM
