Another Offset Question/Help
Old Jun 28, 2006 | 10:58 PM
hai109's Avatar
Racing Hart RS-451 2pc 19 9.0 Front and 19 10.5 rear 26F 26R offsets...Will this clear BBK? I have a 2006 DG coupe...
Old Jun 28, 2006 | 10:59 PM
jimmytango00's Avatar
its the design of the wheel that determines if it will clear a BBK not the offsets
Old Jun 28, 2006 | 11:00 PM
hai109's Avatar
So do you thnk the Racing Harts will clear it? See below
Attachment 46516
Old Jun 29, 2006 | 12:59 AM
truplay8's Avatar
THE BATMOBILE
ask sen_jen
Old Jun 29, 2006 | 01:01 AM
uuu lala that looks freaking good... i cant really see how the spokes are but it does look like they're out... like the work vs-xx are pretty flat from the face so they dont clear BBK's
Old Jun 29, 2006 | 01:06 AM
mwarsh1's Avatar
actually your 100 percent wrong, if the rim has a smaller offset that means the wheels sticks out farther from the hub, hence you can use it with a big brake.
Old Jun 29, 2006 | 01:11 AM
hai109's Avatar
So, would 26 offset clear?
Old Jun 29, 2006 | 01:52 AM
can an expert chime in please
Old Jun 29, 2006 | 02:21 AM
speeddreamz's Avatar
Offset is only a general assumption in brake fitment, real fitment issues exsist with the individual rim and the inner design of the spokes in combination with the offset, and width. Typically, any 19 or 20 inch rim is good for diamater wise, anything around 15-35 typically fits. especially if its a 9 or 91/2 inch rim. The width of the rim and the offset together are a pretty good indicator, if the size is smaller, its a good idea to then look at the inner spokes. +1 for fitment.
Old Jun 29, 2006 | 10:32 AM
Blackbird V35's Avatar
if what you were saying is right then a wheel with a 19 offset and a 6 inch lip would clear a bbk. The offset may be a certain number but the spokes still wont clear a caliper if the design isnt right. You need to look at the width and the offset, as well as the spoke design
Old Jun 29, 2006 | 11:10 AM
Kidcane's Avatar
I almost bought those RH when I was looking. They told me they would clear my Brembos. I ended up going with the Maya STM (very similar to the RH) and they told me the same thing. However since I had changed my rotors out and replaced with drilled slotted Rotora's they did not clear. Luckily all we had to do was add a 7mm spacer and put in longer lug stems and now I am good to go. So I imagine you should be good and if not a spacer should take care of the problem.
seagrasser
May 3, 2022 09:43 AM
Picture Share
Feb 4, 2018 12:41 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
TurTLe*
Sep 29, 2015 01:43 PM
