05 6MT Pinging Question
Old Jul 9, 2006 | 07:14 PM
6MTzer's Avatar
I have the pinging in low RMP's that has plagued some people in the past.
I'm using 93 Octane.
Has anyone corrected this with an ECU reset?
Old Jul 9, 2006 | 07:49 PM
trey.hutcheson's Avatar
I recommend following the threads about the catch can:
Here and here.
My pinging has all but stopped with the addition of this catch-can.
Old Jul 10, 2006 | 01:25 PM
GT-Ron's Avatar
Thanks for the pointers, Trey. I missed you seeing an improvement with this by using the catch-can.
I'd still like know if a reflash has helped anyone with this low RPM pinging, as I think I'm experiencing it as well.
I only recall this starting to happen after the MREV+, headers/cats install, accompanied by some slight sluggishness below 2500 RPM. I don't know that there is a local dyno and so I haven't been able to have it tuned... ...but experience tells me that what I'm feeling/hearing below 2500 RPM is a lot like running too rich. This has been my assumption. It may be due to a screwy A/F ratio after the install of these parts (which I most strongly suspect) but I'll keep this in mind as another possible remedy.
Old Jul 10, 2006 | 01:33 PM
Msedanman's Avatar
O.F. Administrator
With good 93 octane gas, you should get no pinging. All the dealer could do is back off your timing a few degrees, and perhaps clean out the throttle body, and excess carbon in the combustion chamber.
The catch can fix looks like a good one...
C.
Th611
Oct 27, 2015 03:48 PM
RA081024
Aug 18, 2015 07:03 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
nervseele
Jul 17, 2015 11:21 PM
