Catchin' Oil
Old Apr 29, 2006 | 07:40 PM
DaveO's Avatar
Catchin' Oil
Having removed the upper collector from about 25 VQ engines (my own 4 or 5 times) I've always found oil. I got a Greddy oil catch can but didn't find a mounting location I liked.
While checking out the InfinitiFX.com forum I ran accross an interesting way to address this issue... at least until someone comes out with a G35 specific oil catch can.
To give credit were it's due the poster, thread and instructions can be found here. http://www.infinitifx.org/phpBB2/viewtopic.php?t=802
djlfx's parts list is complete as are his instructions. On thing I did differently was to remove the filter element and use the enclosure as a cooler, "wide spot in the road".
A note of caution: The filter came with a warning about synthetic oil and other chemicals. I filled the bowl with Mobil 1 and let it soak for 24 hours. No reaction was noted. I'll provide an update once I get some miles on this mod.
DaveO
Old Apr 29, 2006 | 08:05 PM
Andy2434's Avatar
DaveO,
Thank you for this great find. I was wanting to get a Stillen Oil Catch Can, but did not know where to mount it. This is definitely an excellent solution.
Old Apr 29, 2006 | 11:50 PM
Bobalude's Avatar
Can you elaborate on this?
Old Apr 30, 2006 | 12:25 AM
baileyrx's Avatar
GREAT IDEA!!!
And to think, I actually have 1 of theses things on MY compressor in my garage. PFFFFFF!!!. I was just getting ready to purchased a catch can.
Not any more. Off to the big orange box tomorrow!!
Thanks for the link. This is the reason I love this board.
Old Apr 30, 2006 | 01:10 AM
Andy2434's Avatar
Dave,
I think Pasta did something like this last year. He called it the "Poor Mans Catch Can" or something of that nature. I'm going to hook this up tomorrow.
Old Apr 30, 2006 | 01:13 AM
adamb258's Avatar
i used that smae one on my boosted cobra. you should have seen how much oil it caught after a few thousand har dboosted miles. Cheap, worked great and never had any problems with mine.
Old Apr 30, 2006 | 01:17 AM
baileyrx's Avatar
Originally Posted by andy2434
Dave,
i think he (or maybe someone else) used a fuel filter...
Old Apr 30, 2006 | 08:13 AM
OCG35's Avatar
DaveO
After seeing the residue during plenum removal for ME spacer & Iso - thermal gasket I have been curious about installing a catch can... thanks for the post! - Will there be a descriptive write up in Sport Z?... Diagrams I hope?...
Old Apr 30, 2006 | 02:59 PM
klg35's Avatar
ok, so this filter will trap oil/oil residue from entering combustion area, which is a good thing, right? i too noticed all the oil residue when i installed my iso and spacer.......i just cleaned it up w/rags and not thought much of it, until this post.......oil in combustion area can't be good.......someone with real knowledge please explain.............
Old Apr 30, 2006 | 05:32 PM
DaveB's Avatar
Depends on how much. From what I've seen with my G and from the pics of other posted FM plenums, I hardly see it as a cause for concern. You're lucky to find a tea spoon of oil in the plenum. It's not like all that oil will be ingested at once. It's actually just oil residue accumulation from the emissions system of the car. I've seen VQ30s with far more significant oil accumulation (including my old VQ30) and it never seemed to hurt the performance or reliability of the motors. 250K+ is common place with the VQ. Usually the car falls a part before the VQ does.
Some cars experience significant blow-by under race conditions. GM's LS1 is a prime example and these motors really do benefit from a catch can. The VQ on the otherhand doesn't seem to have the blow-by issue.
Is the catch can bad? No, it won't harm the VQ assuming you understand what you're doing and how to install it. Most guys do it for the bling factor.
Old Apr 30, 2006 | 07:23 PM
klg35's Avatar
good explanation, i would assume that if this oil residue was a problem, someone on this board would of brought it up......so far, no one, which is a good thing.....
Old May 1, 2006 | 12:41 AM
DaveO's Avatar
Gee Pasta installed a fuel filter in the PVC line a while back. I don't believe he's followed up on how well it worked for him.
A wide spot in the road is a way of saying an enlarged area that allows the velocity of a liquid or vapor to slow down and basically drop out of suspension. Combine that with cooling and vaporized hydro-carbons can also be condensed.
I respectively disagree with the majority of your statement.
DaveO
Old May 1, 2006 | 12:45 AM
Andy2434's Avatar
Dave,
Thank you . . . I just installed the oil catch can. It was quite simple and inexpensively done.
https://g35driver.com/forums/engine-drivetrain-forced-induction/97390-makeshift-oil-catch-can.html
Old May 1, 2006 | 02:50 PM
klg35's Avatar
DaveO
who do you know have too much oil going into combustion chamber through the plenum area? my observation is that, yes, there's oil residue at the bottom of plenum, however, has there been enough of these oil residue to be sucked into the c/chambers to be of a concern? who has experienced this?
Old May 1, 2006 | 06:11 PM
DaveB's Avatar
IMO, no. Significant amounts of oil is not getting sucked into the engine...even under high load and aggressive handling manuvers.
As you probably figured out, the oil that accumulates in the plenum comes from extremely small droplets of oil being sucked in from various emissions components under part-throttle (high vacuum) situations. At WOT, there is no engine vacuum, therefore the emissions components are not operating. Since there is pressure differential in the center portion of the plenum (between the six runners), rouge oil droplets/residue will slowly accumulate there. This isn't to say some oil droplets suspended in the air aren't being ingested. I'm simply saying some of the droplets will get thrown into runner valley to the change in pressure. IMO, at WOT, there no way the oil that accumulates in the valley is going to be sucked up out of the valley and into the runners. It's just not really possible because the engine is going to ingest the material with the least resistance (air) plus that oil is largely covered by a metal plate.
Like many G35 mods, this is one of those that typically has a lot of debate. As usual, I'm often the one that goes against the masses
