Catchin' Oil
Old Jun 20, 2006 | 09:04 PM
  #151
godmans's Avatar
Exclamation Please Help!
I believe I would do this now..
Bad news:
After visiting an auto parts store today.. my engine stalled...
It started, pumped to around 1k rpm... then dropped to below 500 rpm..
and stalled...
I am trying to find out what is causing this, since I dun think it is because of the fuel injector hose.. but probably the filter element (even tho I have already drilled an 1/4" hose at the bottom
I will let everyone knows what I find out.. and at the same time, any advice is greatly appreciated .
Old Jun 20, 2006 | 09:27 PM
  #152
G35_TX's Avatar
Several people told you to remove the filter and you haven't yet. That is most likely your problem. If it gets clogged there could be a problem.
Old Jun 21, 2006 | 12:23 AM
  #153
godmans's Avatar
I have removed all the filter element, redone all the fittings with teflon tape, ensure the hose is not collapsing under idling
Yet, my car still stalls under warm start up (where the rpm will drop below 500rpm..and then stall); I have to bleep the throttle during those startups to prevent stalling
Does anyone know what is causing this? or have anyone experienced this?
Any advice is appreciated
Old Jun 21, 2006 | 12:27 AM
  #154
godmans's Avatar
Thank you for your comment Russ, however, I have just removed the filter element 15 mins ago (with the sprial thing still there to act as a baffle; I think that's how most of you guys didi it, right?) and my car still stalls on warm startup...
Any suggestion?
Old Jun 21, 2006 | 12:39 AM
  #155
Andy2434's Avatar
When you drilled the 1/4" dia. hole at the bottom of the white filtering element, were you careful to see that there were no loose pieces that might possibly come loose?
Old Jun 21, 2006 | 12:52 AM
  #156
godmans's Avatar
I was very careful with that; moreover, I have checked tonite that the hole and the surrounding area seems unchange.. which means there is a very low chance that the pipe is clogged
from what I am seeing here.. (from search)
there are usually two reasons behind stalling
1) fouled MAF sensor from oil (filter oil mist)
2) air leak in the plenum or loose vacuum hose.. (I made sure my fuel injector hose is mounted properly...)
Can someone please shine some light on this? I just can't explain why is it stalling..
is it too much air? too little air or what...
Btw, maybe someone can also please check if there is anything wrong with my setup:
Old Jun 21, 2006 | 12:56 AM
  #157
godmans's Avatar
Moreover, as of today (shortly after ~30 miles), with some spirited driving, I have around 2 drops of oil in my catch can already
Old Jun 21, 2006 | 01:04 AM
  #158
Andy2434's Avatar
The install looks good. It looks very similar to the 4 that I recently did. Just to be on the safe side . . . Based on your pic . . . Is the arrow at the top of the bowl assembly pointing from the left to the right?
Old Jun 21, 2006 | 07:38 AM
  #159
InTgr8r's Avatar
Staff ALUMNI (retired)
Did you try reconnecting the old vac line to see if the problem goes away?
Old Jun 21, 2006 | 07:42 AM
  #160
godmans's Avatar
Andy: it is definitely pointing to the right (indicating direction of flow aye?)
Intr: I would probably try tonite.. I am too frustuated yesterday night to try this..
Moreover, I would also try to reset the ecu this morning..even tho it seems that i can never get it works..well, let's try !
Old Jun 21, 2006 | 12:42 PM
  #161
GEE PASTA's Avatar
Florida G35 Club
Godmans
Have you disconnected any cooling lines?
Air trapped in the cooling system could cause hot start problems.
Old Jun 21, 2006 | 02:03 PM
  #162
godmans's Avatar
I didn't remove any cooling lines, all I did was removing the vacuum line and adding the oil catch can + a 3/4 feet fuel injector hose to connect it to the lower intake plenum
So the arrow on the husky air filter should be pointing TOWARDS the plenum aye?
Old Jun 21, 2006 | 02:08 PM
  #163
godmans's Avatar
Originally Posted by andy2434
Dave,
I think Pasta did something like this last year. He called it the "Poor Mans Catch Can" or something of that nature. I'm going to hook this up tomorrow.
To top this off... it should be named as: "Stupid Godmans Catch Can"...who can't get this to work properly
Once again, I really appreciate you guys' suggestions and advices
"kudos"
Old Jun 21, 2006 | 10:35 PM
  #164
godmans's Avatar
Exclamation Updates
Updates:
After:
1) Removing the oil catch can and reinstall the original vacuum hose to the lower intake manifold
2) Cleaned the MAF sensor with MAF sensor cleaner (coz I was suspecting a fouled MAF might cause stalling)
3) popped my stock air filter on, to make sure the MAF won't be fouled because of oiling from air filter
My car still stalls during warm startup..
I am frustuated... will bring to Dealer... but dunno when will they take a look at this
Old Jun 21, 2006 | 10:58 PM
  #165
GEE PASTA's Avatar
Florida G35 Club
Originally Posted by godmans
Updates:
After:
IM sure its something simple.
Please" check for a vacuum leak. This with a high plenum temp could cause a problem.
Remember, we all are brothers here.
I have made a few friend here in Utah with the tech at the infiniti dealer here.
In many cases here we have found that coolant temps and air pockets in the coolant system have caused the problem you are talking about. It could be this simple.
Understand that your buddies here will get this figured out.
