Catchin' Oil
Old May 14, 2006 | 01:00 AM
  #91
DaveO's Avatar
djl,
I'd like to take this opportunity to thank you for this cost effective real world mod. Your explanation of "why" is quite detailed. Mine's slightly simplier and while not totally complete the basic theory is sound.
All engines experience "blow-by" the piston rings. Worn engines and those with FI usually experience more blow-by. This blow-by pressurizes the crankcase. On the VQ the pressurized crankcase is vented by the PVC valve to the lower collector's oil gallery which is under vacuum. The oil/combustion by-product vapors are drawn through the oil gallery's six small holes (one per runner) into the intake air stream. The air/oil vapors mix with the fuel injected at each intake port lowering the fuel's octane rating.
Thanks again!
DaveO
Old May 14, 2006 | 01:18 AM
  #92
Andy2434's Avatar
djlfx,
Hehehe . . . I just got home awhile ago and I find your post. Thanks for the info and more importantly . . . Thanks for this excellent mod. I do not know where this is going . . . But I am quite pleased that all of that oily gunk is being trapped. Thank you!
Old May 14, 2006 | 09:48 AM
  #93
djlfx's Avatar
DaveO & Andy,
Glad you guys find this mod. helpful, that's what these forums are all about. Now if only someone can come up a $1 per gallon gasoline alternative and we'll be all set.
djl
Old May 14, 2006 | 11:16 AM
  #94
bosssho's Avatar
Yes guys, and you know who you are, thanks from all of us technical neophytes!
Old May 14, 2006 | 12:11 PM
  #95
Cracker Red's Avatar
Thats a cute comment Pasta boy....
Please let me know how it is that on a motor making upwards of 320 crank hp out of 1.9L, the VQ is so technically advanced. It's so damn advanced that the CAM TIMING increases the exhaust velocity, overcoming the backpressure a muffler creates.... back atcha..
I'm out, I've said what my experiances are, with real-world testing. If you wanted to save yourself some time and $$, you'ld tap into the exhaust where you plan on putting this venturi probe, and figure out how much vac you can't pull and at what point. Of course, this would require actual testing, and I'm sure the internet knowledge world will come to your rescue.
Old May 14, 2006 | 12:39 PM
  #96
OCG35's Avatar
Originally Posted by DaveO
djl,
Thanks again!
DaveO
A detailed explanation followed by a summarized explanation!!! Hot damn - this website is starting to re-develop into what it was a year ago and prior... a great place to get real-world information and/or subjective opinions. This is the kind of stuff that allowed my to make informed decisions about the mods I did (and have been VERY happy with!).
Thanks for the info guys!.. I hope this type of dialog flows into some of the other threads without all the BS that has phucked it up in the recent past.
Old May 14, 2006 | 02:02 PM
  #97
InTgr8r's Avatar
Staff ALUMNI (retired)
Great thread guys....
Did my MREV-2 install today.
I was surprized at the amount of oil sitting in the gallery.
...One more thing on the to do list
Old May 14, 2006 | 05:15 PM
  #98
OCG35's Avatar
is there a write on other threads about your MREV-2? (I'm not trying to hijack the board here, but I am interested in your impressions).
Old May 14, 2006 | 05:35 PM
  #99
InTgr8r's Avatar
I'll post something later...
I Don't want to clutter this thread.
Old May 14, 2006 | 11:37 PM
  #100
DaveO's Avatar
Here's what my catch can "caught" after 780 highway miles. The container is a standard shot glass. The dipstick level appears the same... maybe my engine is an oil generator.
Mobile 1 5W-30 - 03 doggie door A/T Sedan with 28,768 miles
DaveO
Old May 15, 2006 | 12:15 AM
  #101
Thats not really to bad IMHO DaveO.... If you think about the motor loosing 3 times that much in ~3000K miles, or even 5 times that much, it's doubtful you'ld ever even notice it on a dipstick.
It would be interesting to do a leakdown test on those motors that were producing more and less oil. My GUESS would be those with the best sealing rings would push more oil out, but on something like the VQ, it's doubful that a good running motor would show much of a change even between say 3% and 6% ring seepage...
Do you have anything you can bump your timing up with, or modify the map at all?
Old May 15, 2006 | 01:28 AM
  #102
DaveO's Avatar
I wouldn't consider this an abnormal amount of oil (I just don't want to burn it). I've never used a noticable amount of oil between oil changes.
My cars initial timing was bumped over three years ago as were the A/F and Timing maps.
DaveO
Old May 15, 2006 | 01:38 AM
  #103
Andy2434's Avatar
DaveO
I agree with Dave. Any amount of this gunk being trapped is better than the alternative of the said going back into the engine.
Old May 15, 2006 | 04:24 PM
  #104
InTgr8r's Avatar
Posted in the sticky thread as well, but if you missed it....
FWIW..
Here's some silicone vac hose that I found.
Vibrant Performance
Old May 15, 2006 | 04:41 PM
  #105
trey.hutcheson's Avatar
Query -
How does one dispose of this oil?
