HELP! clutch, transmission, flywheel
Old Jul 11, 2006 | 11:29 PM
kebeeeen's Avatar
i will try to call ICA if all fails any dealers in socal you guys reccomend me taking my car too?
Old Jul 11, 2006 | 11:31 PM
Skyline_G35's Avatar
English dude, English
Try??? Come on man. It's not that hard. Have your VIN # and call the 1800 number.
Old Jul 12, 2006 | 05:27 PM
kebeeeen's Avatar
ok i just got off the phone with ICA after arguing with them back and forth for a good hour they are telling me they will not warranty my clutch and fly wheel that i will have to pay for it. Any other idea guys?
Old Jul 12, 2006 | 05:39 PM
upgrade the argument to a manager. or Pm me and I will give you my name and you can call back to ICA and ask them why they covered mine but they wont cover yours.
Old Jul 12, 2006 | 05:44 PM
Texasscout's Avatar
For not much more than $1300, you could get a lightened flywheel and a better clutch and Press Plate. IF you have to pay for it, that is.
Heck there are a lot of posts where guys have had to replace the clutch at less than 15K! I'm with you, 56K is a bit short.
Old Jul 12, 2006 | 05:52 PM
dofu's Avatar
20 Year Member
If the dealer doesn't want to deal with it, you can take the thing to a tranny place when you get a new clutch/flywheel and at the same time while they have everything taken apart, have them open up the tranny to change out the synchros. The synchro itself should be very cheap, a couple dollars or so a piece, if even that much.
Old Jul 12, 2006 | 06:07 PM
kebeeeen's Avatar
yeah i also tried talkin to them about the synchros but they are telling me its my clutch blah blah blah but honestly my clutch feels fine other than the fact that it doesnt go in smoothly into 3rd a couple of times. (no grinds maybe happened like once or twice) I also PMed you Skyline_G35. Thanks for your guys help!
Old Jul 12, 2006 | 07:38 PM
kebeeeen's Avatar
Just got off the phone with a representative but they wont budge. I tried asking for a higher manager but their is not one on duty. So i gotta wait for the dealership and ICA to talk to each other. Sigh hopefully theyll replace it under warranty...
Old Jul 12, 2006 | 08:41 PM
papagz's Avatar
man they are pulling your leg. ive had 3 trannies replaced and clutch replaced as well.....keep trying. you will get it done, without paying a dime. thats what warranty is about
Old Jul 12, 2006 | 11:20 PM
Aman's Avatar
I know a thing or two about engines so this is really throwing me off!
How does a FLYWHEEL wear out? It's a weight and that is it. It helps to smooth things out and does a few other things but really all it does is SPIN!
Please educate me as I don't see how a flywheel can wear out.
Flywheels can warp, and get some serious hot spots in them which make clutch engagement very un-pleasent, so yes they can wear out. But the only real reason a clutch would have something to do with gears being notchy is if the clutch is not fully dis-engageing when depressed.
And BTW, how are you guys going through so many trannys? Is the 2005 tranny just that much better? I have 35k miles on mine with no issues whatsoever.
Old Jul 13, 2006 | 04:13 AM
dofu's Avatar
20 Year Member
If you're not grinding, then it just might be the clutch bearing... if that's the case, you should be getting some chatter noises here and there too. And the fix for that would be a new clutch and disc...
Old Jul 13, 2006 | 10:00 PM
kebeeeen's Avatar
It grinds rarely but i dont get any chatter noise. They are still telling me they will not warranty my clutch and flywheel and that i have to pay for it. This sucks...considering its so expensive sorry for complaining just pissed cuz my car has so little miles and all these problems...
Old Jul 13, 2006 | 10:08 PM
Texasscout's Avatar
I would watch them remove it (they could switch it out with a bad one) and make them give you the parts. Have a third party inspect them. Be sure you tell them this BEFORE they start.
Old Jul 14, 2006 | 12:08 AM
What happened when you used my name with ICA?
Old Jul 14, 2006 | 12:21 AM
  #30
ttrank's Avatar
Grocery getter
I am a little late to this thread but I can tell you for sure it has nothing to do with your flywheel. I just had this battle with my dealer a few months back with ~47k on my car. With 56k they do not have to replace your clutch or flywheel for you and would be doing a big favor if they did. Try to fight it but remember they are not required to since they are wear items.
The flywheel needs to be replaced because it is dual-mass and very hard to machine. Over time flywheels get hot-spots, imperfections and become uneven. If you do not repair these problem areas your next clutch will slip more and wear out much faster. If we had a single piece flywheel then it could be machined and re-used. If the wear is minor you may be able to find a shop that can fix it for you but the dealer is not going to be happy about waiting while you go out and do it.
They typically charge between $1100 and 1200 plus another hundred or so install for a new flywheel. My dealer wanted $1600 for the flywheel and clutch, I was able to find an oem flywheel online for ~$800 but did not get it. I had already purchased a UR flywheel and just rushed over a JWT clutch. They installed them for me. I was happy since they did have enough reason to not even give me a new tranny since I have so many mods.
