View Poll Results: Is your rear quarter panel molding warped/disfigured
YES
26
14.94%
NO
148
85.06%
Voters: 174. You may not vote on this poll
Coupe rear quarter window issue.
Old Jul 13, 2006 | 02:40 PM
Archangel's Avatar
^Yep, that's the issue.
I'm in an '05 with 92XX miles, also sits in the sun at work. Passenger side is fine, but you can see the Driver's side above.
Old Jul 13, 2006 | 03:03 PM
ericson112's Avatar
i have this same problem on both sides...i got a 05 coupe
Old Jul 13, 2006 | 03:18 PM
Ciccio's Avatar
Originally Posted by vjquan
Mine has it as well, but very slight. If fact, I would not have known about it until I read this thread. It can only be seen in bright sunlight and looking down the sight lines of the molding. Didn't bother me before, not going to bother me now, especially since it seems to be a very common issue. I think you're probably facing an uphill battle by taking this to Infiniti. I wouldn't want the dealer to replace it anyway since they may scratch it, not put it on correctly, etc.
Mine is very slight as well - PS. Just one, about 1in. from the forward end. It's barely noticeable. DS is clean. Something I wouldn't worry about at all, as they might make it even worse.
__________________________________________________ _________________________
2006 Coupe| 6MT| Athens Blue| Graphite| Navi| Prem| Aero| RAS| VentureShield Clear Bra
Old Jul 13, 2006 | 03:24 PM
speedracerg35's Avatar
i've discovered the trim is very pliable. mine was fairly bad on the pass. side, so i took a plastice body shop putty spreader and slid it between the car and the molding and straightened it out. i think it is an installation issue.
Old Jul 13, 2006 | 03:32 PM
Archangel's Avatar
^Has it stayed straight after you did this or does it slowly go back to warping?
Old Jul 13, 2006 | 08:05 PM
overdrve's Avatar
I noticed that mine is pretty bad on the driver's side too. I always thought the tint guys did it by applying heat to shrink the tint to the window around the dot matrix. Didn't realize it could have been a manufacturer defect. A quick question though, of all of you who see the problem, how many have had your windows tinted? Just curious as it seems to be a part issue since cars on the lot have this problem. But I just can't recall if my molding was warped before I had my tints put on.
Old Jul 13, 2006 | 08:46 PM
g35pat's Avatar
I have a 2003.5 and my passenger side rear quater window moldings are in perfect condition. Note that I'm always washing my car myself with non-pressurized running water. My guess is that the damage is being caused by Car Wash or pressure wash...
Old Jul 14, 2006 | 12:18 AM
WaLLy's Avatar
hhhmmmm gotta check that out tomorrow!
Old Jul 14, 2006 | 09:21 AM
forced347's Avatar
My car has always been hand washed......plus the new OEM parts that were ordered came in damaged.
Old Jul 14, 2006 | 10:02 AM
spwong's Avatar
05 6mt
passenger side molding f'd up from day one, there was also a little blip in the sunroof gasket, but some pressure and heat got it right and has stayed.
Old Jul 14, 2006 | 01:15 PM
Jamaica2G's Avatar
Mine has been like that since whenever... 15k miles 2005 ...
IMHO you guys are picky. I saw it but never thought that I'd take it to the dealer unless it caused wind noise or leaked.
Honestly, I wouldn't touch it in case they screw something else up in the process.
Adrian
Old Jul 14, 2006 | 02:28 PM
forced347's Avatar
Adrian
I had a Mustang that was featured in 10 National magazine... I'm a little **** about my cars. If this was a Kia I would expect this....it is however a luxury Sports Coupe that costs a premium and it should have a better QA process.
Old Jul 14, 2006 | 05:55 PM
kidtronix's Avatar
Optional
Wow, never seen this. I'll keep an eye on mine. Almost ready to turn 10,000 miles (13 months old)
Old Jul 14, 2006 | 09:40 PM
when i saw mine, i checked a couple of new g's on the lot while my oil was being changed. almost all of them have one or the other distorted.
Old Jul 14, 2006 | 11:43 PM
  #30
WaLLy's Avatar
checked mine out today and nothing so far!
