help horn not working
Old Jul 20, 2006 | 11:21 PM
alan21's Avatar
i installed the greddy front mount intercooler for my turbo and i had to move the horns.I did nothing but move them alittle when i got everything buttoned up they didnt work. Any ideas? anyone with the turbo kit experience this or is it just a freak thing? thanks for any imput
Old Jul 20, 2006 | 11:28 PM
Clemmdog's Avatar
Check the grounds and all wiring... could have come a little loose.
Old Jul 20, 2006 | 11:34 PM
drunkin master's Avatar
check your fuse.
Old Jul 21, 2006 | 02:43 AM
GTT's Avatar
GTT
G35 Twin Turbo
check your fuse.
++1
Old Jul 21, 2006 | 02:45 AM
hai109's Avatar
You horn has one wire going to it...You body is the ground Take the horn out and reinstall it...If you move it to a different location then you need to make sure the bolt is ground the horn...Oh...and check the fuse like they said too...
Old Jul 21, 2006 | 10:07 AM
gspotter's Avatar
The G's horn is so quiet anyway.
Old Jul 21, 2006 | 10:56 AM
alan21's Avatar
thanks for the help guys were is the fuse for the horn located though
Old Jul 21, 2006 | 01:57 PM
Msedanman's Avatar
O.F. Administrator
+1.......grounding.
C.
Old Jul 21, 2006 | 03:33 PM
alan21's Avatar
where is the horn fuse located??????
Old Jul 21, 2006 | 05:18 PM
kidtronix's Avatar
Optional
Start using your middle finger instead.
Old Jul 21, 2006 | 05:22 PM
Msedanman's Avatar
O.F. Administrator
On my M, it's a relay and is located in the battery compartment.
It's probably the same location for your coupe.
C.
arora_g35
Apr 16, 2026 02:52 PM
jsimonk
Dec 22, 2023 03:49 PM
obender66
18 Inch
Mar 13, 2016 12:20 PM
Rehman2009
Jul 27, 2015 03:23 AM
attarday
Jul 15, 2015 04:03 PM
