clicking noise while accelerating?
So here is the problem...When i let off the brake and start to accelerate it will make 2 real quick click noises...then when each gear changes in manual mode it will click once as well...also while downshifting in manual mode it makes a single click for each gear???>>!! Does anyone know what this is or have the same problem.
Yep...
There is a TSB for it.
I have an appointment to bring mine in for the repair on Monday.
According to the TSB, they either remove the rear axel and replace the screws in it or they just grease it up... depending on the severity of the problem. It's a very common issue apparently.
Originally Posted by MJ2315
"Technical Service Bulletin" and its not a one day job, its actually about 0.7hrs labor for one side and 1.1 hrs labor for both. i just waited for mine.
If they actually take off the axels and replace the bolts as well as regrease, I've heard it's as much as a 4 hour job depending on if they do one side or both.
Quick question
So TSB are free ?
I just got my G last week and so far I got the click and that fuel fill up problem.
So could I just call a dealership & tell them I got those 2 problems & I know they are a TSB ????
So TSB are free ?
