My Dyno
Old Jul 30, 2006 | 04:21 PM
nmanti's Avatar
You may want to look at your ECU. With that many breather mods you're going to be running lean. If you can get the car to dump a little more fuel in those numbers can go even higher.
Old Jul 30, 2006 | 05:33 PM
GTT's Avatar
GTT
G35 Twin Turbo
nice #s
Old Jul 30, 2006 | 07:01 PM
Rock1's Avatar
Originally Posted by dpjax
Its a 2006. I had the parts installed by Velocity Trends in Jacksonville, FL.
It was hot as hell.
I got the MREV2, plenum spacer, Z-Tube, Stillen intake, stillen damper along with 4 dyno runs for right around $400.
I bought all the parts online.
I see you are in the Jacksonville area. I hope to see your car around.
Also looks like you got a pretty decent deal. I wish Stage6 had a freakin' dyno. I'd recommend them 100% for any work
Did you get any A/F ratios?
Old Jul 30, 2006 | 09:37 PM
dpjax's Avatar
All-in-one reply.
Isn't there a Stage 6 near Philips Highway? Thats close to work. Where do the G35 guys hang out around here? I'm in a Z club but no G's in the group. I also have a 300ZX TT I'll be selling soon - can't keep both toys.
I bought all of it from everythingg35.com
I can definitely tell a difference in how quickly I get power. It made the car a little louder but its not bad.
The A/F ratios are in the dyno graph. Doesn't look too lean to me, any comments?
Old Jul 31, 2006 | 12:47 AM
trey.hutcheson's Avatar
I suggest you call the shop and ask them to send you the run files. You can download the winpep viewer program and look at the runs in different views. The reason I suggest this is because the graph is plotted along mph, not engine rpm.
Because of that, and the ****ed up scale, it's hard to really see your a/f's. If anything, it looks like you're running rich, which would make sense in the heat. But it also looks like you're running PIG rich, really low in the rpms. If you can get the run files and the viewer program, scale it out a bit better and export a new graph. But from first looks, I'd say you've got a lot of power left waiting for a good tune(utec).
Old Aug 1, 2006 | 12:18 AM
Hydrazine's Avatar
I had an intimidator exhaust put in last weekend. This weekend I put in a stillen engine damper, stillen airbox, z-tube, MREV + spacer.
The 2 lowest were with only the catback for a baseline.
Best Before = 250.16 RWHP & 217.48TQ
Best After = 257.42 RWMP & 238.50TQ
What do you think?
Thoes are some killer gains!
Your peak may have only gone up by 7, but much of the curve below the peak looks like it went up around 20HP! And the peak value extends much further down the RPM range.
Excellent gains.
seagrasser
May 3, 2022 09:43 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
