header rasp?
Old Jul 30, 2006 | 05:32 PM
WRXKiller's Avatar
header rasp?
i just got my top speed headers put on (everything else stock, ztube popcharger and spacer) and i was wondering if anyone else got a rasp. when its cold its pretty bad but when it warms up it gets somewhat better but still there...could an exhaust leak cause a rasp? if anyone else encountered this problem, what might the remedy be? any help would be much appreciated
thanks,
you fellow g who HATES rasp
Old Jul 30, 2006 | 05:46 PM
Captain Baller's Avatar
yes, the exhaust leak could cause the noise. Did you replace the gaskets? Even if you didnt replace the gaskets it should be ok, but you should replace them and also just make sure the bolts are torqued to the right specs. Call the dealer for the torque specs and buy a toque wrench unless you already have one and then basicly you can get er done!
Old Jul 30, 2006 | 05:48 PM
Calvin's Avatar
Overglorified Altima
my e-cutouts are raspy when car is cold too. but when it warms up (like 30 seconds later..) its fine
sorry cant help any more
Old Jul 30, 2006 | 05:49 PM
WRXKiller's Avatar
i used the new gaskets, however i didnt measure the lbs torqued down....just tightened until tight enought to feel comfortable about driving with them. i know a leak causes a noise, i had one on my mustang, however i was wondering if a leak can also cause a rasp?
thanks for the reply
Old Jul 30, 2006 | 06:03 PM
99atlantic's Avatar
a leak will cause a TIC TIC TIC sounds
I get some rasp after a cold start, but it goes away after a minute or driving.
im' pretty sure it's caused from a matching of headers w/ stock catback....those who replace the catback seem to loose the rasp completel.y
Old Jul 30, 2006 | 06:36 PM
WRXKiller's Avatar
thanks for the replys...i fixed the problem....running a loose y pipe (where in connects with the midpipe) will cause a nice deep sound with rasp at 2500-3500 rpm...it did sound nice minus the rasp.... oops!
Old Jul 30, 2006 | 06:52 PM
Calvin's Avatar
i just changed my mid pipe..so could my rasp be because the bolts arent torqued to the right specs? im assuming i need an in-lbs torque wrench..gotta get me one of those
but before i buy can anyone confirm that i need an in-lbs torque wrench? dont feel like buyin it if i dont need it..
and what are the "specs" that i tighten the bolts at?
Old Jul 31, 2006 | 01:11 AM
Calvin's Avatar
buuummmppp
Old Jul 31, 2006 | 01:43 AM
ON's Avatar
ON
well like i told you hero, with exhuast, i'd tighten everything down until i feel like it wouldn't fall off. i've had problems where i've tighten to specs only to have the nut come loose (the wheels to be exact...not cool at all). so better to tighten down and make sure its on there tight. want to make things safe for you and other drivers as well. the last thing people need to worry about is things flying off of your car.
and anything with exhuast, i would think you would need a ft-lb wench, not in-lb.
Old Jul 31, 2006 | 02:30 AM
Calvin's Avatar
^^ meh in-lbs ft-lbs its all good lol i dont have either so whatever..oh yeh this is where your ramps or jacks or whatever you have (forgot) come in handy
Old Aug 1, 2006 | 12:18 AM
Calvin's Avatar
stupid question: should there be a gasket at each end of the midpipe?
magnetism80
Jan 27, 2016 12:57 PM
NJ6MT
Oct 9, 2015 05:02 PM
lavtxa
Sep 21, 2015 11:51 AM
Atwork
Intake & Exhaust
Sep 20, 2015 03:36 AM
Albanian122
Engine - Exhaust
Sep 5, 2015 11:23 AM
