Differential oil change
Old Jul 31, 2006 | 01:15 AM
ModMe's Avatar
Hey guys, i've been trying to change the differential oil in my G but the bolt is bothering me. I couldn't find any tool to open the bolt. Do you guys know the size and name of the tool bit to open the differential bolt? Thanks a lot.
Old Jul 31, 2006 | 07:39 AM
combatcraig's Avatar
I haven't looked at mine. Is it just a square hole? If so, just use a ratchet with no socket on it.
Old Jul 31, 2006 | 08:52 AM
SilverII's Avatar
I think they call it a hex drive.....
Old Jul 31, 2006 | 10:19 AM
Captain Baller's Avatar
why are you changing it? unless you hvae around 65,000- 80,000 you dont need to change it.....
Old Jul 31, 2006 | 10:37 AM
Soopa G's Avatar
all depends on how you drive the car..........I changed mine to synthetic at 10K
Old Jul 31, 2006 | 01:05 PM
its already synthetic from the factory.....
Old Jul 31, 2006 | 01:16 PM
JDM V35's Avatar
I was thinking about changing mine with some good A$$ oil called
Shell SPIRAX "S" Gear Oils These Gear Oils are heavy duty, synthetic lubricants that are formulated to meet the severe demands imposed by cold weather and high operating temperatures. They excel in low temperature performance, high temperature stability, water separation, and resistance to viscosity loss by shearing.
They only drawback is that it's only avalible in a 5 gallon bucket. So you will have enough to do 5 or so cars. I paid $125.00 for it.
DG
Old Jul 31, 2006 | 11:34 PM
ModMe's Avatar
I just got my baby. Even though she only has a lil bit over 5k on it, i want to change out everything so that she's running on new stuff. I dont know the driving style of the previous driver, i just thought it'd be a good idea that i clean her out.
I found out that the bolt is called 10mm Hex. After draining the oil, the plug was covered with black metal chips. The oil was very dark! And she only has 5000 miles on her! I'm glad i changed it out. =]
zoop425
Mar 29, 2016 05:51 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
