WTF is that noise?!?!
Old Aug 7, 2006 | 12:50 PM
johnbigbootie's Avatar
I got in my car this morning to drive to work. Came up to a stop light, as I was waiting I heard a steady, high-pitched beep coming from the car. I looked all around the dash, no dummy lights were on. My seatbelt was on. I thought maybe it was something coming from the radio so I turned the radio off but the noise stayed on. Steady high-pitch tone lasted for about 10 seconds then stopped. Then a few seconds later started again, lasting another 10 secs or so then stopped, and never came back. Never saw any warning lights or other indications that something was wrong. Thoughts?
Old Aug 7, 2006 | 12:53 PM
LjN_728's Avatar
Low tire pressure?
Old Aug 7, 2006 | 02:03 PM
98intrigue's Avatar
Originally Posted by LjN_728
Low tire pressure?
Yahtzee.
Old Aug 7, 2006 | 02:09 PM
chilibowl's Avatar
Originally Posted by 98intrigue
Yahtzee.
Yeah but wouldnt that turn the TPS light on ?
Old Aug 7, 2006 | 02:38 PM
Greeknasty's Avatar
def tire pressure...happened to me first day i got my g...drivin along then all of a sudden
DUNNNNNNNNNNNNNNNNNNNNNNNNN
i thougt damn car was singin..but i saw a exclamation mark or somethin..go fill up ur tire
Old Aug 7, 2006 | 03:26 PM
gspothawaii's Avatar
look for a nail or something in the tire while youre at it.
Old Aug 7, 2006 | 09:54 PM
thanks all...I did not see any warning light but I'll def check my tire pressures
Old Aug 7, 2006 | 10:46 PM
partyman66's Avatar
Turn your key to the on position with your engine not yet started, and make sure that your Tire Pressure warning light actually turns on in the gauge cluster.
In case you don't know what it looks like, it's an Exclamation Point (!) in the middle of the dash. I forget the exact location of it in the dash, but it should be somewhere in the middle, I think beween the tach and speedometer.
Could be something as simple as the light not functioning, but the Tire Pressure warning sound still works.
But as everyone else already said, it sounds like it's your Tire Pressure Warning noise.
Do you have the Navigation system? The Nav system is setup to warn you if you try to drive with any of your doors open and also warns you of a few other abnormal situations, but I'm not sure if it makes a noise too or if it just flashes the warning on the Nav screen.
Old Aug 8, 2006 | 01:16 AM
flessner's Avatar
it's an orange/amber idiot light on the right hand side. it looks like (_) with a ! in the middle of it. happened to me the first week i had mine, and didn't know wtf was going on either. pleasantly surprised it was just low pressure. went to walmart and got a cheap 5 dollar digital gauge, and sure enough a couple tires were around 31psi.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
