clutch pedal sticking?
Old Aug 18, 2006 | 11:10 PM
brianlitt's Avatar
After I pull the clutch out it sticks (it seems to be disengaged at this point) and then pops 2 inches or so back to the regular position. Anyone ever had this, is this a big deal?
Old Aug 18, 2006 | 11:40 PM
mbdizzle's Avatar
Ive been having the same problem on my 05 6mt with just under 15k miles.
Old Aug 19, 2006 | 12:27 AM
techi13's Avatar
me 3
Old Aug 19, 2006 | 12:44 AM
rdurkin05g35's Avatar
i think i have the same problem.. after i have been driving for a while in the heat my cluth gets real limp for about the first two inches and then engages and the same for when i try to disengage it sticks and the longer i drive the farther down the pedal starts to stick ... i think it is the slave cylinder but i havnt had a chance to take it and find out
Old Aug 19, 2006 | 05:02 AM
WaLLy's Avatar
do you hear like a clicking noise?
Old Aug 19, 2006 | 09:05 AM
brianlitt's Avatar
no weird noises. The car operates normally, but it just sticks a bit on the way out. Actually you can push it in to this point too. It's such a definitive stopping point for the clutch that I almost thought it was a "feature". You can push in the clutch very lightly and it will halt you here, and then push it on the rest of the way. Pulling it out is the same story. It pull sout to this poitn and then all the way.
Old Aug 19, 2006 | 12:53 PM
g35donny's Avatar
You want to check the clutch pivot joint. My 03' was doing the same thing and I ignored it. Next thing I knew I was stranded with my pedal stuck to the floor.
Old Aug 19, 2006 | 12:59 PM
RBull's Avatar
Rated M
It's not right. Take it in to the dealer and have it corrected.
mbe32
Nov 13, 2015 11:09 PM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
Hogbone
Sep 28, 2015 06:44 PM
jbmw002
Sep 10, 2015 12:54 AM
