is this the correct tape?
Old Aug 24, 2006 | 02:20 PM
04Gwhiz's Avatar
is this the correct part number for the tape that you use when you are driving long diastances and want to cover the front so no debris damages teh front bumper and will it remove easily off the painted surface?
http://products3.3m.com/catalog/us/e...er/output_html
Old Aug 24, 2006 | 02:21 PM
abcquackyxyz's Avatar
Blue tape or green should work. the lime green is used for painting cars either one is fine.!
Old Aug 24, 2006 | 02:23 PM
04Gwhiz's Avatar
but which one should i use?
http://products3.3m.com/catalog/ca/e...er/output_html
one says safe relase and the other says safe release for delicate surfaces
Old Aug 24, 2006 | 02:26 PM
how long is your road trip i would say the blue is fine 15 days under direct sunlight not too bad. i thought i saw one that has 30 days w/o sticking it was at walmart at the paint section. but teh blue tape is there and its pretty cheap
Old Aug 24, 2006 | 02:31 PM
Alan's Avatar
i use blue painters tape from home depot. no need to be fancy.
Old Aug 24, 2006 | 02:35 PM
Msedanman's Avatar
O.F. Administrator
You might want to pm Downshift when he returns from his trip north. He used this tape on his G so he'll know exactly which one to use.
C.
Old Aug 24, 2006 | 02:36 PM
GT-Ron's Avatar
+1 Blue Painters Tape is the important thing to look for. I like 3M and the Duck one. You might want to get some that's 2"-3" wide, to cut your effort down.
Old Aug 24, 2006 | 02:37 PM
04Gwhiz's Avatar
thanks but i just get confused when i see safe release and safe release for delicate surfaces...dont kow which one everyone here uses
Old Aug 24, 2006 | 04:15 PM
SilverII's Avatar
get a car bra
Old Aug 24, 2006 | 04:40 PM
gesekee19's Avatar
ive made 3 trips in the past month up to northern california. First time i Used the green one and it worked great and came off nicely. second trip, I uesd the blue tape on my G and on my girlfriends bmw...both protected well but on our trip, some of the blue tape came loose and started slapping different body panels leaving glue residue all over...taking it off was even a little more difficult as well. third trip, I used green again and it worked great! no rock chips to report of. I got my G re-painted a month ago too! i would stick with the light green one made by 3M,.,.it comes off easier and leaves no residue...but make sure your stick the tape on securly or its gonna fly off.
Old Aug 24, 2006 | 05:19 PM
04Gwhiz's Avatar
whats the part number of the green tape?what is it called?
Old Aug 24, 2006 | 05:27 PM
Basheer's Avatar
Call the Cops
Old Aug 24, 2006 | 05:33 PM
Calvin's Avatar
Overglorified Altima
Old Aug 25, 2006 | 01:39 AM
caskyline's Avatar
Former Vendor
Use the blue painters tape
Old Aug 25, 2006 | 01:47 AM
AL ASPIRATED's Avatar
you can use blue 3m painters tape, you find find them at home depot in different sizes
