HELP on replacing clearance lights
Old Oct 15, 2003 | 10:52 AM
zippiziggi77's Avatar
I have bulbs for clearance lights , but i couldnt figure out how to replace it. Please leave me a note if anyone know how to step by step.
Thanks
Old Oct 15, 2003 | 03:34 PM
Cameron38's Avatar
Re: HELP on replacing clearance lights
You have to get to them the same way you get to the headlight bulbs. You have to jack up the front of the car, remove the wheel (highly recommended), remove the wheel well liner, then you can get to the bulbs. A pain in the ***, and definitely a big learning curve after you have done the first side. If you're going to do it.. I recommend changing out the high beam/fog bulbs for some Sylvania Silverstars while you're at it. They match the low beam Zenons much better than the factory bulbs.
Old Oct 15, 2003 | 04:05 PM
nyckid's Avatar
are those silverstars the best match to the factory xenons? or are the PIAA Sparks 8000k a better match? i want a bulb that will match my factory HIDs... anyone can recommend the best possible match?
Old Oct 15, 2003 | 04:30 PM
redwillow's Avatar
20 Year Member
jack the car?? remove the wheel?? are you nuts!
i can assure you, you don't need to do ANY of that for the clearance lights.... just pull all the plastic clips holding the front part of the wheel well cover off, there are also 2 screws in that area you need to remove. Then there are around 10 bolts on the bottom area under the front bumper that hold that part of the front wheel well cover in place... take those out and the cover will be free... You can just TURN the wheel to get access to the clearance light bulb holder. Twist it and pull the holder out, there is the bulb
here is a picture from "TCFOOL" on FA of that area with the cover off. The clearance bulb holder has a flat plastic part sticking out of it, as you can see in the picture.
03 6MT coupe, red/willow, premium, aero, splash guards, alum pedals, clear corners, 15% tint
Hasanbaloch
Feb 29, 2024 08:45 PM
Luisgalvan33
Jul 19, 2018 08:16 PM
igking
Jul 19, 2015 01:12 AM
Ashton35
Jul 17, 2015 10:11 AM
