Sedan Rental Faster??
Old Sep 8, 2006 | 10:35 AM
jasonlee4180's Avatar
You know...the last few times i've taken my car in for service and gotten a rental for the day, I've noticed that the auto Sedan I get "feels" faster and torquier than my 6mt coupe.
The midrange seems to pull more aggressively than it would in my coupe.
My only reasonings for this is because it's stock and I've done more breathing mods that may have sacrificed some lowend and midrange grunt? The powerband can't be that different, right?
Just curious if anyone else has this same feeling?
Old Sep 8, 2006 | 10:51 AM
1BADV6's Avatar
You are not efficient in driving a stick--that is my first guess. I felt the same way the first time I had a sedan loaner, when I was new to the manual tranny. Now, I feel that auto's are subpar.
Like I said, just guessing.
GT-Ron's Avatar
The mods are a possibility. Not sure what year 6MT you have, but if it's '05-later then less torque is exactly what you're feeling, as the other motor produces more of it that the '05-later 6MT RevUp motor.
In addition, the sedan is lighter.
Old Sep 8, 2006 | 11:35 AM
Calvin's Avatar
Overglorified Altima
this has already been discussed..
https://g35driver.com/forums/showthr...+faster+rental
Old Sep 8, 2006 | 11:40 AM
trey.hutcheson's Avatar
I had an 06 sedan loaner late last year, 5AT. And it felt torquier. But that thing just gave up after 4500 to 5k rpms.
And being that I currently have a sedan, the weight wasn't a factor.
Old Sep 8, 2006 | 11:44 AM
You know, even as a sedan owner, I'm tired of reading that last bit. We're not talking 500 pounds of difference here...
And that's not directed at you man, just the sedan/coupe weight difference argument in general.
Old Sep 8, 2006 | 11:58 AM
GT-Ron's Avatar
Isn't it around 150-200lbs or so lighter? Granted, it's not a ton, but it's significant enough to feel a difference. I'd certainly like to drop that.
But, more significant, is the TQ difference between the two motors. I'm sure that's the bulk of it, but without knowing for certain if he has a RevUp, the difference in weight was worth mentioning.
FWIW, as a coupe owner, I'm also tired of hearing about the sedan being lighter.
Old Sep 8, 2006 | 12:06 PM
Originally Posted by aHero4Eternity
Ahh....didn't see that post. I haven't been checking all posts lately. Glad I'm not the only one with this mind trickery.
And I believe the sedan is only about 50lbs or so lighter than the coupe...based on someone's previous post in the linked thread.
And btw...I have an 04 so it's the same non-Revup motor as the sedan I drove.
Old Sep 8, 2006 | 12:26 PM
logik05se's Avatar
the sedan loaner is NOT faster then my 06 6mt. Gaurentee you that.
Old Sep 8, 2006 | 12:54 PM
LuXXXz's Avatar
dude i keep tellin u coupe guys
sedans are faster the coupes
because they're lighter, and especially w/ sedans that change midpipes from sedans to coupe's its more of a difference
think about it
same engine w/ less weight
get it through ur heads coupe guys u dont drive a ferrari
Old Sep 8, 2006 | 01:29 PM
Sumlime311's Avatar
think about it
HAHA this guy is funny!!!
Old Sep 8, 2006 | 01:44 PM
Oh I wish it were that significant. I don't know the differences for 03 or 04 to the pound, but I've read it's roughly 100lbs, though I doubt it's that high. For the 05 6MT's, the "published" curb weights were identical between coupe and sedan. For 06, I believe the coupe gained a little more than the sedan, but it's marginal.
Old Sep 8, 2006 | 01:47 PM
Funner567's Avatar
its a 40lb difference.... nothing that sedan owners should gloat about. the 5at is higher because it has more tq off the line.
Old Sep 8, 2006 | 01:55 PM
jclit's Avatar
WOw, its a 12 pound difference.. Why do you sedan owners think your faster? Your Aerodynamics sucks compared to our, do you guys have zero-lift?
Sedan: 3,512 lb/ At 3449 lbs.
http://www.infiniti.com/g_sedan/specifications.html
Coupe 3,524 lb
http://www.infiniti.com/g_coupe/specifications.html
Old Sep 8, 2006 | 02:04 PM
I don't want this to become some Sedan vs Coupe, which is better debate
I liked the extra low/midrange grunt from the Sedan. I was just pointing out that my coupe didn't feel the same after I got it back. Even though they're the same engines...they didn't completely feel the same, though you'd think they would.
